I am a little skeptical about the mechanical strength of this tanckThe tank will be made out of 50mm thick PP sheets.
you have to be a super specialist to weld PP
The way you're doing is fine then, it's to give general dimensions and the fabricator will go into the details himself.
In v0.18, view creation was changed in TechDraw. The view orientation is taken from the orientation in the 3D space. So to generate a top view in TechDraw, you first need to set the top view in the 3D space. It may be possible to change the orientation of the base (principal) view from its properties, but I haven't tried.
Yepp, that was the key issue.
App::Document::_RecomputeFeature(): Unknown exception in Feature "ProjItem" thrown
App::Document::_RecomputeFeature(): Unknown exception in Feature "ProjItem004" thrown
App::Document::_RecomputeFeature(): Unknown exception in Feature "ProjItem005" thrown
Gui::Command::activated(0): Unknown C++ exception thrown
Well, if you are interested, I can post you some photos, once it is manufactured, which is 6-8 weeks.
