I left this project for a few days to prepare for some job interviews and just re-attempted it. You're either gonna have to explain it to me like I'm an idiot, or find someone who will, hahaha . But in seriousness, can you please explain this to me in a bit more detail, or point me towards a clear tutorial? I would greatly appreciate the help .chrisb wrote: ↑Sun Feb 03, 2019 8:48 pm I would go a different way:
- Create a ShapeBinder of the chimney's Sketch007 in "Roof right"
- create a DatumPlane in the Sketch's plane (you can attach the following sketch directly if you prefer). This is what it looks like:Bildschirmfoto 2019-02-03 um 21.43.55.png
- attach a new sketch on the DatumPlane
- create a rectangle with the ShapeBinder as external reference
- make a pocket and set "Symmetric" and "Through all".
Boolean Cuts moving body but not performing cut in Part Design
Re: Boolean Cuts moving body but not performing cut in Part Design
I think this is dealt with in one of the tutorials of forum member HarryGeier. If not, come back, you will have learned something anyway.
I think that there is a real bug somewhere here - PartDesigh boolean really acts weird. I tried just a simple cut of one cylinder with another cylinder - while the cut looks correct and changing the placement of the negative cylinder modifies the cut I can not make it or any of its sub elements visible for subsequent edit... I will probably make some experiments later...
Have you looked at the documentation before jumping to the (false) conclusion there's a supposed bug?
PartDesign Boolean
Look for the Display property entry.
PartDesign Boolean
If this is not just for demonstration purposes but for a real model, then you should not make a cut anyway. You would use a subtractive cylinder instead. There are very few use cases where PartDesign's boolean operations are needed. All additvie features perform what in Part workbench would be a create and a fusion, while the subtractive features perform a create and a cut in one single step.
Text engraving, designing a holder for already designed item,...
I dont really see the need for that setting (so at first glance it looks like an err) - as with all other features you just hide the underlying sketches so why not just hide the bodies but don't disable their visibility? Probably there is a good reason.
Anyway it looks that the OP is hitting the second limitation mentioned on that page - moving the body from 0,0,0 before performing the cut.
Assuming we're talking about engraving on a flat face, then no second Body is necessary. Create a Draft ShapeString, drag and drop it over your Body, attach it to the face you want, then create a Pocket. Bam! you're done.
https://forum.freecadweb.org/viewtopic. ... 65#p271565
In the case of a logo imported as SVG, I'd have to check, I doubt the imported geometry could be dragged & dropped in a Body, but what could be done is to convert it to a sketch with the Draft Draft2Sketch tool, and move the sketch inside the Body.
Okay, fine. Please let me amend what I said: yes, there are use case where a Boolean between different bodies will be necessary. But in most topics that have been posted so far, it wasn't necessary to use two (or more) bodies. The overwhelming majority of cases, a single-body approach works and is simpler.
This was discussed on the forum by the developer, but I don't recall the gist of it. It's definitely a usability issue.
As I already replied in the first page of this topic.
