Ticket #3691 - Bug in draft scale. Only integers work
JAndersM
Postby JAndersM » Sun Feb 03, 2019 8:34 pm
Just found this bug issue #0003691 using version 0.18.15780 of FreeCAD.
So I start a discussion here as directed.
Reason: Added ticket number to thread title
Re: Bug in draft scale. Only integers work
Postby chrisb » Sun Feb 03, 2019 10:29 pm
Works as it should. You probably have set the number of decimals wrong.
Besides that it is really annoying that people are unable to read the really huge banner in the bug tracker telling you have to create a forum discussion before creating a ticket.
And if a ticket is created it should contain a link to the forum discussion. In this special case there is no need to do so, I will close the ticket right away.
Sorry for being so explicit.
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15780 (Git)
Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e
Python version: 2.7.12
JAndersM
Postby JAndersM » Mon Feb 04, 2019 8:56 am
1 No it does not work.
This is then a problem with the default settings. I have not changed any setting. Just downloaded and installed the latest version on a computer with no previous version installed.
2 I did not submit the bug report. But wanted to get attention to this bug.
3 There is no big yellow banner when you open the page. Might be one when you first submits a bug. As I saw konda1 wanting a forum thread I started one.
Roy_043
Postby Roy_043 » Mon Feb 04, 2019 9:56 am
I think there is indeed an issue with the default settings.
If you reset the settings (Menu: Edit > Preferences > Reset button) the number of decimals is set to 0.
But if you then go to Menu: Edit > Preferences > General button > Units tab, the number of decimals is wrongly displayed as 2.
I would call this a BUG...
JAndersM
Postby JAndersM » Mon Feb 04, 2019 10:10 am
:) Thanks!
Postby chrisb » Mon Feb 04, 2019 10:28 am
Sorry to JAndersM, you were the wrong adressee for my complaint.
It takes almost 1/3 of my screen:
You are right, something's wrong.
I have observed the following:
- Initial setups have the number of decimals set to 2. This works as can be seen e.g. in Sketcher setting.
However, these settings do not apply to the scale dialog, where decimals are even more important as in length values. I can fix this by
- open Preferences
- open General->Units without changing anything!
- conform settings with ok
Now the scale dialog shows 6 decimals.
Postby chrisb » Mon Feb 04, 2019 10:36 am
I have reopened the ticket.
Roy_043
Postby Roy_043 » Mon Feb 04, 2019 10:41 am
Yes, my initial analysis is not entirely correct, only the scale fields are affected.
Maybe you have to login to see the yellow banner? I don't see it either.
JAndersM
Postby JAndersM » Mon Feb 04, 2019 10:43 am
Not mine. Might be that I am not logged in to the bug tracker. I just googled the problem and found the bug report.
Good.
Postby chrisb » Mon Feb 04, 2019 12:11 pm
It would be sufficient if it's only shown for registered users, who want to create a new ticket.
