Use any Model or: Make 3 pads all stacked one on each other, so now we have pad-zero,pad001,pad002 and sketch-zero,sketch001,sketch002. Normally at this point pad002 is selected showing the entire model, now open sketch-zero and close it, then open sketch001 and close it, the model disappears. That doesn't seem right.
OS: Windows 7
Version: 0.18.15780 (Git)
Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e
Python version: 2.7.14
OCC version: 7.2.0
Model disappears (solved) config file problem
Re: Model disappears
I can't reproduce that, after closing any Sketch FreeCAD recalculates and the 3D view reverts to as it existed before the Sketches were edited, but showing the changed geometry...freedman wrote: ↑Sun Feb 10, 2019 5:59 pm Make 3 pads all stacked one on each other, so now we have pad-zero,pad001,pad002 and sketch-zero,sketch001,sketch002. Normally at this point pad002 is selected showing the entire model, now open sketch-zero and close it, then open sketch001 and close it, the model disappears.
OS: Ubuntu 18.04.1 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Python version: 2.7.15rc1
Qt version: 5.9.5
Your model does not disappear. Here is one I generated and it fails. I selected faces and sketched on them.
- disappear1.FCStd
- (23.8 KiB) Downloaded 61 times
I can reproduce this in your file. Also, Sketch001 and Sketch002 cannot be properly edited. Weird.
However, if I recreate both sketches and the pads, the behavior returns to normal.
OCC version: 7.2.0
"It is a poor workman who blames his tools..."
Don't have time now, I will reset my config file and try again. That has to be next.
Re: Model disappears (Solved ) reload config files
It was the config files.
Thanks
Thanks
