Master sketch + Shapebinder
Hannu
Location: Strängnäs - 1hr drive west from Stockholm, Sweden
Postby Hannu » Sun Feb 17, 2019 1:08 pm
Hi
I'm having trouble with Shapebinder not displaying anything in the current body, what am I missing?
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15860 (Git)
Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0
Python version: 2.7.12
ElectronicsOutdoors_v3.FCStd
(14.77 KiB) Downloaded 11 times
/Hannu
Hannu
Re: Master sketch + Shapebinder
Postby Hannu » Sun Feb 17, 2019 1:59 pm
Forgot one thing...
Tools > Dependency Graph
Fails miserably on the attached thingie.
/Hannu
Bance
Postby Bance » Sun Feb 17, 2019 3:31 pm
Make the body you wish the shapebinder to reside in active by double clicking it (it should have a blue background,) then select shapebinder tool, and select reference geometry, close dialogue, the shapebinder will reside in the body but will not be visible if the ref geom is still visible, make ref geom invisible and the shapebinder appears!
HTH Steve.
Postby chrisb » Sun Feb 17, 2019 3:45 pm
It isn't missing. Hide Sketch001 to see the ShapeBinder.
Hannu
Postby Hannu » Sun Feb 17, 2019 6:53 pm
Ahh... Make the relevant BODY visible (press space), there are many ways to make mistakes.
/Hannu
NormandC
Postby NormandC » Mon Feb 18, 2019 2:23 am
Not for me. And it shows a linking error (the red arrow).
You cannot attach an external sketch to a plane inside a Body, the sketch needs to be inside the body. Either detach your sketch from Body's XZ_Plane and just let it be "free floating", or create a Part container (Std Part) that will contain the three bodies, and attach the sketch to the XZ_Plane plane of the Part container.
OS: Ubuntu 18.04.2 LTS
Version: 0.18.15897 (Git)
Hash: 36dc7b42425dcb08abf6313c6dee6ce306b7bcdc
Python version: 3.6.7
Qt version: 5.9.5
Locale: French/Canada (fr_CA)
Hannu
Postby Hannu » Tue Feb 19, 2019 7:02 pm
Hmm... The intent was to keep it as clean as possible, i.e. to use the "Master Sketch" principle fully.
I seem to have failed with that.
edit: Hrm? How do you create a sketch WITHOUT attachment? - NOT click on any of the options? I haven't even considered that possible...
Detach => Sketch WB, Attach to plane and select "Do not attach" at the end?
I also have a more evolved file now (too large to attach, dropbox -> https://www.dropbox.com/s/eij69uae1a67p ... FCStd?dl=0)
and seem to not have got it built in way that allows changes to the "Sketch_Master"
(all named constrains except "ringCenterRadius" should allow adjusting... and as always; Fillets fail, but didn't really expect anything else).
And also here i get a crash; /usr/bin/dot (from graphviz, in bezier)
as I try to use dependency graph.
/Hannu
DeepSOIC
Postby DeepSOIC » Thu Feb 21, 2019 12:30 am
Create the sketch from within Sketcher workbench, not PartDesign.
You can also detach a sketch using attachment editor, which can be invoked by clicking "..." button next to MapMode property of the sketch in property editor.
Hannu
Postby Hannu » Sat Feb 23, 2019 3:02 pm
Based on this discussion https://forum.freecadweb.org/viewtopic. ... 23#p288623
I guess there is at least one redundant constraint in "Body_Top > Revolution > Sketch002" - in the file on dropbox (v4, not the initial file).
This does not show, the sketch is "Fully Constrained" with green lines all over.
/Hannu
