unwanted rounding for subtractive cylinder
openBrain
Re: unwanted rounding for subtractive cylinder
Postby openBrain » Mon Feb 18, 2019 4:22 pm
meme2704 wrote:
Mon Feb 18, 2019 4:09 pm
I have just taken the procedure to zero:
I open your file, I measure your hole, = 0.53mm, including in techdraw
I modify your hole to 0.525mm I measure it (by the two techniques) = 0.525mm, I save, I reopen, I measure = 0.53mm, Damned :mrgreen:
I modify "Preferences" to 4 decimals places, I close Fc, I restart Fc, I redo all the tralala, and .... (roll of drums) .... the hole is to remain at 0.5250mm ...... youpie :lol: :lol:
it should be written on Fc's pediment:
:!: "DO NOT FORGET TO CLOSE Fc FOR CHANGES OF PREFERENCE TO BE TAKEN INTO ACCOUNT" :!:
This workaround doesn't fix here. What does happen if you double-click the function and just validate by clicking "OK" in the Tasks tab ? Here it is rounded (to 0.530 mm, so keeping 3 decimals). ;)
meme2704
Postby meme2704 » Mon Feb 18, 2019 4:39 pm
I do not understand what you call a workaround
if you do not modify "Preferance", close, reopen, it will remain to 2 decimal rounded
I put 4 decimals, to check that it would put well 0.5250 and would save it, but indeed, 3 are enough if you do not fall below the micrometers
Postby chrisb » Mon Feb 18, 2019 4:51 pm
I cannot confirm meme's fix either. Using the dialog the values are always rounded to 2 decimals. It is even worse: this error exists for subtractive and additive primitives, tested for cylinder and cube.
Any other places before we create a bug report?
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15860 (Git)
Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0
Python version: 2.7.12
Postby chrisb » Mon Feb 18, 2019 5:00 pm
The issue existed already in 0.17.
meme2704
Postby meme2704 » Mon Feb 18, 2019 5:42 pm
Bof!, if you want, I do not use any magic formula to get this, you can check with this file, if your machine is set to 4decimales of course
Cylinder-rounding-issue5250.FCStd
(20.53 KiB) Downloaded 3 times
openBrain
Postby openBrain » Mon Feb 18, 2019 5:48 pm
I confirm that as soon as you edit the function as previously mentionned (double-click function & validate values - without changing - in Tasks tab), the value is rounded again. ;)
EDIT :
openBrain
Postby openBrain » Mon Feb 18, 2019 5:57 pm
I did some tests also and it seems like problem exists with all values of all additive & substrative primitives. ;) For example I tested with wedge, all values are concerned.
Oppositely, I found no problem with other values that are editable in the Tasks tab (eg. pad or pocket length).
I found another strange behavior : for example, a value of 2,525 is rounded to 2,520 (floor) while 8,525 is rounded to 8,530 (ceiling).
meme2704
Postby meme2704 » Mon Feb 18, 2019 6:00 pm
Démerdez-vous j'ai fais ce que j'ai pû
bejant
Postby bejant » Mon Feb 18, 2019 6:17 pm
Using the file in the OP, FreeCAD works for me as expected using these Edit > Preferences > General > Units settings:
Edit: After quitting FreeCAD, opening it again, and creating a new Sketch from Part Design, constraints in the 3D window are whole numbers - no decimal point.
Units system: Standard
Number of Decimals: 6
OS: Ubuntu 18.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Python version: 2.7.15rc1
Qt version: 5.9.5
blue and strike-through = edit
openBrain
Postby openBrain » Mon Feb 18, 2019 6:23 pm
Problem also exists here with 6 decimals. ;)
Qt version: 5.9.5
Locale: French/France (fr_FR)
