Mirror feature of Body
m.cavallerin
Post by m.cavallerin »
Hi all,
is there a way to mirror a body to a new one and to sub-sequentially fuse them together?
thx
OS: Linux Mint 19 Tara
Version: 0.18.16268 (Git) AppImage
Build type: None
Branch: (HEAD detached at FETCH_HEAD)
Hash: 9a4632f4384c8f7496baf75aa38a46be74649d83
Python version: 2.7.6
Qt version: 4.8.6
Screenshot from 2019-02-18 18-34-36.png (158.55 KiB) Viewed 1126 times
Re: Mirror feature of Body
Apply Part->Mirror on the body and fuse the body with its mirror (again in Part workbench).
m.cavallerin
Hi and thx,
it worked, but I can't improved the quality of the final surfaces.
The line in the middle is kept even if I set refine to True.
In any case, On the other hand, when I fuse these wing and cylinder, the latter has lower quality for surface.
Just a note, I don't know if this issue is already tracked somewhere else.
m.cavallerin
I attach my file, if someone want to investigate deeper.
Regards.
web1.fcstd
lightweight file
(888.86 KiB) Downloaded 18 times
Only cylindrical and flat faces can be refined. But where is the problem? It is still the same solid. If you don't want to see the lines change , change the draw style to "Shaded".
m.cavallerin
chrisb wrote: Tue Feb 19, 2019 12:22 pm It is still the same solid.
About fusion feature:
If I export the STEP file and import it in Salome, you can see the problem.
"Shaded" is just a way to cover the problem, not the solution.
m.cavallerin wrote: Tue Feb 19, 2019 12:02 pm I attach my file, if someone want to investigate deeper.
The middle part is missing in this file.
m.cavallerin
chrisb wrote: Wed Feb 20, 2019 12:52 am
the file uploaded has only two bodies.
Once they're fused together, one of the external faces on Body "CILINDRO" is being corrupted .
The middle element is visible if the step file is exported in STEP and imported in Salome (e.g.).
