Lofting between solids
zinob
Postby zinob » Tue Feb 19, 2019 2:16 pm
This is a simplified example. I have (multiple) solids and i want to generate "wedges" in between them. Here i have downgraded the solid and then lofted between the surfaces, but on the real model this is impractical. Both because i have so many places that i want to shim and because i want to be able to keep working with the other faces of the solid, as a sold afterwards. Is there any other way? I guess that i could also create sketches on the faces and import the underlying geometry, but that would also get very messy very fast.
before
Screenshot from 2019-02-19 14-04-56.png (18.95 KiB) Viewed 73 times
Screenshot from 2019-02-19 15-03-03.png (85.56 KiB) Viewed 73 times
Of if someone has any suggestion on how to extract multiple faces along a curved surface without these wedges appearing that would also be really helpful..
padding problems.png (15.51 KiB) Viewed 73 times
FreeCAD Version
OS: "Fedora release 29 (Twenty Nine)"
Version: 0.17.Unknown
Build type: Unknown
Python version: 2.7.15
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
microelly2
Re: Lofting between solids
Postby microelly2 » Tue Feb 19, 2019 3:58 pm
You can use a Facebinder object from Draft WB to get the face links you need for a Loft
