TechDraw HLR parameters for section of a multibody
Hi everyone,
I started to play with the TechDraw module (by the way, it's great that such a module actually exists...) and I'm struggling with an issue regarding the tuning of the HLR parameters for section views.
I didn't manage to find a set of parameter able to distinguish between:
- the hidden lines of geometry "behind" the cut plane,
- the interfaces between distinct bodies,
The visibility for both of them seem to be driven by the "Data/HLR Parameters/Hard Hidden" parameter and their thickness by "View/Lines/Hidden Width", see attached example.
I would like to display the contacting interfaces between bodies but not the hidden lines. Is this somehow possible?
Thanks!
OS: Debian GNU/Linux 9 (stretch)
Version: 0.18.15900 (Git) AppImage
Hash: a73b10203ab1cb31df4a8763b050d64da8e81580
Python version: 3.6.7
Qt version: 5.6.2
Thanks!
Qt version: 5.6.2
- section.FCStd
- (15.49 KiB) Downloaded 42 times
Re: TechDraw HLR parameters for section of a multibody
Can you expand on what you want? If you want different lines then maybe a different view?I would like to display the contacting interfaces between bodies but not the hidden lines. Is this somehow possible?
Sure!
In section.FCStd I have two distinct bodies, touching each other.
In TechDraw, the view "View" shows the interface between the two bodies, as expected.
In the view "Section A-A", the interface is by default hidden, I want to show this interface.
However, I don't want the "hidden lines" (not generated by the interface but by other geometries) to have the same appearance as interfaces.
Is it clearer?
Is it clearer?
- wandererfan
I think I'm going to need a picture to understand.
Does setting "ShowCutSurface" to false help you?
- ShowCutSurface.png (31.72 KiB) Viewed 1709 times
- wandererfan
Just guessing, but how about this?
- sectionOrigin.png (3.47 KiB) Viewed 1706 times
An issue with the gatlib view A-A, why isn't there a line between the two bodies? I could understand if there was one body but with two bodies I would expect a line.
- line_snip.JPG (11.48 KiB) Viewed 1701 times
Thanks for your answers, I think we're getting there! Sorry, I thought my problem was easier to explain, but my test file was apparently not as self-explanatory as I thought. To sum-up:
- No, "ShowCutSurface" does not help
- No, I do not want to move the section plane
- YES! I expect to see "a line" between the two bodies
I attach a little picture, in Section A-A, I would like to display (which is quite standard):
- The hidden feature of the top body as a dashed line
- The interface between the bodies as a solid line
I'm not able to set them independently.
Thanks for your feedbacks!
- section.png (16.9 KiB) Viewed 1681 times
- wandererfan
So you've already discovered this: But you'd like to have this: In the current code the Source shape(s) are fused together before doing the section cut. Sometimes this is required to get good results. Maybe there should be an option.
[ Edit: woops, line removed, shouldn't have been posted! ]
Yes, I'd like the "unfused source" behaviour, using the modified code. Thank you very much wandererfan.
I actually think that the "unfused source" should be the default, but providing an option is ok.
I'm not familiar with the freecad source code (but not too scared by code in general), can this parameter be easily found/tweaked?
Look at the macros, you can learn to write them and set/reset almost everything.
