Trying to resolve "cyclic dependency detected"
meme2704
Re: Trying to resolve "cyclic dependency detected"
Postby meme2704 » Fri Mar 15, 2019 9:29 am
And, of course too, share the solution with other users.
Ok, in this case, it would be necessary to make a communication Urbis & Orbis and in Latin :lol:
I work very little with arch Wb which seems to me to be the most adaptable and less consumer of kO
For example the same sketch can be used several times: that of the outer walls is used for the walls, the foundations, the slab
another advantage, a sketch not closed and constituted of several segments even non-continuous or which intersect, works
With the Fenetre tool all doors and windows are placed in one operation,
same for the roof
maison de maître.FCStd
(37.78 KiB) Downloaded 6 times
maison de maître.PNG (11.96 KiB) Viewed 270 times
t.lemaitre
Postby t.lemaitre » Fri Mar 15, 2019 10:46 pm
chrisb and kisolre, I try to find my redundant constraints.
The sketch view of the V0.17 shows them (or you can use the tool of the sketch Wb (Ctrl + Maj + R) if, like me, you didn't know :x). I tried it with a new sketch with redundant constraints.
Then, I looked in my three main sketches : Pièces_maison (284 constraints), Murs_maison and Murs_garage. There is no redundant constraints !!!
same for the roof
Are we speaking about the same file I attached in my first message?
It's almost exactly what I did. For example, I'm using the sketch Murs_maison to build the wall, the slab, the cladding, etc.
Except for the windows : I want to be able to choose there position/size with a dimension between the windows and a partition for example.
I will however modify my workflow for the windows to stay parametric :
  1. draw a sketch representing the external limit of the windows (with constraints for the position)
  2. then make a window
  3. then attach the windows' sketch to the sketch drawn in the point 1
As I told, my report view were not much verbose and I find an option in the preferences to help me : I just added the message in the menu General and the tab "Fenêtre de sortie".
After a recompute, the result is :
App::Document::recompute(): cyclic dependency detected
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
('comparison result:', 2)
<input>:115:6: Could not resolve property: sectionfill
TIMING - ProjItem007 GO spent: 309.495 millisecs in HLRBRep_Algo & co
TechDraw::GeometryObject::addGeomFromCompound edgeCompound is NULL
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
COPLANAR
('comparison result:', 0)
<input>:125:6: Could not resolve property: sectionfill
TIMING - ProjItem006 GO spent: 408.582 millisecs in HLRBRep_Algo & co
TIMING - ProjItem006 GO spent: 422.407 millisecs in HLRBRep_Algo & co
TIMING - ProjItem001 GO spent: 381.431 millisecs in HLRBRep_Algo & co
TIMING - ProjItem GO spent: 451.774 millisecs in HLRBRep_Algo & co
TIMING - ProjItem002 GO spent: 388.700 millisecs in HLRBRep_Algo & co
TIMING - ProjItem005 GO spent: 326.246 millisecs in HLRBRep_Algo & co
TIMING - ProjItem GO spent: 453.397 millisecs in HLRBRep_Algo & co
TIMING - ProjItem001 GO spent: 395.707 millisecs in HLRBRep_Algo & co
TIMING - ProjItem002 GO spent: 414.161 millisecs in HLRBRep_Algo & co
TIMING - ProjItem005 GO spent: 328.242 millisecs in HLRBRep_Algo & co
TIMING - ProjItem007 GO spent: 333.505 millisecs in HLRBRep_Algo & co
At the end, there is many lines like this:
When you add every lines of this kind it gives 4,6 s. Almost what I'm waiting!
And then I understood I'm loosing my time because of the techdraw objects.
If I delete the group "Plans", FreeCAD is really faster than with: even if I still have my cyclic dependencies, I solved my problem of slowness (and may be the growing RAM too).
I thought cyclic dependencies were the source of the problem, but it's not.
Thank you all!
Postby chrisb » Sat Mar 16, 2019 5:27 am
It is probably not sufficient that some of your sketches don't have redundants. usually none of them should have them.
t.lemaitre
Postby t.lemaitre » Sat Mar 16, 2019 2:47 pm
For sure, I should not have redundants constraints. I will try to find and delete them.
Here is my current report after a global recompute of my file :
Sketcher::RedundantSolving-DogLeg-
Sketcher Redundant solving: 1 redundants
Sketcher::setUpSketch()-T:0.024
Sketcher::Solve()-DogLeg-T:0.001
Sketcher::setUpSketch()-T:0.018
Sketcher::setUpSketch()-T:0.002
Sketcher::setUpSketch()-T:0.001
Sketcher::setUpSketch()-T:0.005
Sketcher::Solve()-DogLeg- Failed!! Falling back...
Sketcher::Solve()-LevenbergMarquardt- Failed!! Falling back...
Sketcher::Solve()-BFGS- Failed!! Falling back...
Sketcher::Solve()-SQP(augmented system)- Failed!! Falling back...
Sketcher::Solve()-SQP(augmented system)-T:0.004
Sketcher::setUpSketch()-T:0.003
Sketcher::Solve()-SQP(augmented system)-T:0.001
Loading Drawing module... done
('Debug: Error computing areas for ', u'Murs maison001', ': unable to project face: ', '[Vector (13833.0, 11980.0, 2504.0869565217417), Vector (-497.0, 11980.0, 2504.086956521741), Vector (-497.0, -497.0, 3697.5391304347836), Vector (8226.0, -497.0, 3697.5391304347836), Vector (8226.0, 2870.0, 3375.478260869567), Vector (13833.0, 2870.0, 3375.478260869567), Vector (13424.0, 3279.0, 3336.3565217391324), Vector (13424.0, 11571.0, 2543.208695652176), Vector (7817.0, 3279.0, 3336.356521739132), Vector (7817.0, -88.0, 3658.417391304349), Vector (-88.0, -88.0, 3658.4173913043487), Vector (-88.0, 11571.0, 2543.2086956521757)]', ' (face normal:', Vector (-4.1689547525126404e-17, 0.0952175768039399, 0.9954564847684633), ')')
Sketcher::Solve()-SQP(augmented system)-T:0.002
Exception (Sat Mar 16 11:11:56 2019): Property not found: Dim001
('Debug: Error computing areas for ', u'Bardage maison001', ': unable to project face: ', '[Vector (13877.0, 12024.0, 2499.8782608695674), Vector (-541.0, 12024.0, 2499.8782608695665), Vector (-541.0, -541.0, 3701.747826086957), Vector (8270.0, -541.0, 3701.7478260869575), Vector (8270.0, 2826.0, 3379.6869565217403), Vector (13877.0, 2826.0, 3379.6869565217407), Vector (13833.0, 11980.0, 2504.0869565217417), Vector (-497.0, 11980.0, 2504.086956521741), Vector (13833.0, 2870.0, 3375.478260869567), Vector (8226.0, 2870.0, 3375.478260869567), Vector (8226.0, -497.0, 3697.5391304347836), Vector (-497.0, -497.0, 3697.5391304347836)]', ' (face normal:', Vector (-4.1689547525126404e-17, 0.0952175768039399, 0.9954564847684633), ')')
Sketcher Redundant solving: 2 redundants
I can read there is redundant constraints and cyclic dependencies, but I don't know with which object!
chrisb wrote:
Fri Mar 15, 2019 12:30 am
Document::recompute(): DWire071 still touched after recompute
Document::recompute(): Extrusion042 still touched after recompute
Document::recompute(): Sketch058 still touched after recompute
How do you get such a report, with the name of the objects? It will be helpful for me.
Postby chrisb » Sun Mar 17, 2019 7:21 am
I did nothing special. I used 0.18-almost-release-version and made a recompute. In 0.18 the sketches containing errors like redundancies are then marked with an exclamation mark.
t.lemaitre
Postby t.lemaitre » Sun Mar 17, 2019 3:18 pm
Ok. Then I'll wait for the 0.18 release in the ppa.
Anybody knows the approximate delay for this?
PS : I browsed the Release_notes_0.18. It seems to be really interesting.
NormandC
Postby NormandC » Sun Mar 17, 2019 3:27 pm
I'm supposed to do it this weekend, if I can stop procrastinating and browsing this forum... :oops:
Meanwhile you could simply add the freecad-daily PPA to your software sources, and install the freecad-daily package. It's currently equal to the final 0.18.16093 release, and it won't be updated for a few days I think. It won't conflict with the freecad-stable PPA.
t.lemaitre
Postby t.lemaitre » Sun Mar 24, 2019 7:26 pm
After other bugs, I finally installed the ppa-daily version ;)
NormandC
Postby NormandC » Mon Mar 25, 2019 12:39 am
Yeah, I haven't succeeded in packaging 0.18.16093 in the freecad-stable PPA yet, because I wanted to switch to a new alternative system allowing switching between Python 2 and Python 3. Kurt (kkremitzki), who did all the original work for Debian, will look at it when he gets a chance, hopefully soon.
bejant
Postby bejant » Mon Mar 25, 2019 1:23 am
Look at the Dependency Graph posted by chrisb and notice the red arrow pointing up from Sketch059 to Wall015 (you re-named them to French names).
