In the XY-plane I've sketched a rectangle with a diagonal. Now I want to rotate one of the triangles (two side edges + diagonal edge) along the diagonal, so that the rectangle appears to "fold". This means that that triangle will end up in another plane than the XY-plane. How can I do that?
(Also don't understand how to attach an image. It is supposed to refer to an URL. What URL would that be?)
Rotating out of sketching plane
Last edited by TavernSenses on Sat Mar 16, 2019 11:43 am, edited 4 times in total.
Re: Rotating out of sketching plane
Hi TavernSenses, welcome. Your images are not visible here, they point to a file on your local harddrive. In Part workbench you can change the Placement of the sketch, in PartDesign it is AttachmentOffset.
You cannot rotate elements out of the sketch plane, this is not supported. As chrisb suggested, you need to rotate the whole sketch.
If you could explain what you are after, we could advise you on ways to accomplish it. What do you intend to do with that folded rectangle?
Hi TavernSenses, and welcome! I think you need two Sketches, each Sketch containing only a triangle and each Sketch on separate Planes, but we need more info from you so we aren't guessing.
Thx everybody for the swift reply. You indeed understood my intentions, Bejant (sorry for the missing image. I don't know what URL I should refer to).
It seems to me that FreeCAD is very much centered around starting with a 2D image ("sketch"), which is then worked out to intricate level, before being extruded into 3D through procedures like "pad", "pocket" or "loft". I'm used to working with Blender or Sketchup, in which you can drag a vertex freely into 3D space right away. They also both have this "Protractor" tool, for which the described action of rotating a 3-point polygon would be a piece of cake.
However, the constraint feature is something that doesn't exist in Blender or Sketchup, and it's really powerful. That's what really makes me want to move over to FreeCAD. But it looks like I got stuck right away in what is supposed to be a very simple operation. If I placed the two triangles into two separate sketches, in two planes at an angle, would it still be possible to constrain their respective elements on each other (e.g. the length of the edges), as if they were still in the same sketch?
Hi
I usually have my idea of troll ...
But before, small remark of troll, in my country, the line which joins two summits of a surface is called diagonal we learns this since the nursery school)
and I'm clever like a gnome, I place my rectangle with 2 opposing vertices tangent with one of the axes of the sketch
I make a clone, I use placement to rotate it from the chosen angle
I use the tool "Degrade" Draft Wb (the big blue arrow down) and apply it to the clone, I get 4 Edges, I erase the 2 from below
I select the top two, and create a new skit that will be linked to it
I make these 2 Edges "Referand (big square blue) which makes them purple, and I trace the new segment of the skit in supperposition.
But that energy spent while I would have to do the new direct sketch incline Bonet simply draw the desired triangle
Well, I'm tired, I'm going to visit my friends the gnomes
- triangle levé.PNG (24.65 KiB) Viewed 610 times
How to attach an image is explained here:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
After attaching the image, I clicked the Inline button, to include the image somewhere other than the end of this reply:
Anther way tp place the second Sketch is to use Expressions, which is what I did in the attached file. I gave names to the Constraints in Sketch, then used Expressions to use the values of those named Constraints in Sketch001. Sketch001 is Mapped (attached) to the vertical face of the hypotenuse side of Pad, but Mapping Sketches directly to faces usually makes the model easy to break, so it would be better (although more complicated) to use Expressions to locate Sketch001.
More info regarding Expressions is here:
https://www.freecadweb.org/wiki/Expressions
File from which the above image was made:
OS: Ubuntu 18.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.16000 (Git)
Hash: 337c9c936f4c686fd476c5eeb3397d0d09f6b258
Python version: 2.7.15rc1
Qt version: 5.9.5
I'm pretty sure TavernSenses doesn't know what you're talking about there, and without knowing the backstory it doesn't make sense...
To load an image you need to click on the "Attachments" tab below the editing window and the click on "Add files". An input window will open in which you can select the file from your computer to be uploaded. Then click "Place inline" to add the file to your post.
[Edit: Same thing bejant just said.]
Gene
You make the mistake of thinking he gives a damn about it, he doesn't. It's the very nature of a troll. Next he'll write something in French here, yet again. All of it to taunt us, again, proving my very point that he is indeed a troll, no matter what helpful advice he might happen to provide. Even broken clocks are right two times a day...
