Open the file (in v0.18) and try drawing a draft circle. Immediately any lines/circles disappear, as if obscured by the ImagePlane. If you then rotate the view slightly they become visible again.
Can anyone confirm this?
Version: 0.18.15938 (Git)
Hash: acdd4b097bbaf6d94bc09cf38f25924bd5d3e778
Python version: 2.7.14
OCC version: 7.2.0
Locale: French/France (fr_FR)
Bug? - Drawing draft circle against ImagePlane makes all lines disappear
- benjaminwharton
- circle bug.FCStd
- (574.53 KiB) Downloaded 26 times
Re: Bug? - Drawing draft circle against ImagePlane makes all lines disappear
It looks like the faces are drawn first, then imageplane and then edges:
OS: Windows 8.1
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
OCC version: 7.2.0
Locale: Bulgarian/Bulgaria (bg_BG)
When all the features are at the exact same z-level the result is often undefined. Just move the image plane in the -z direction a small amount and the other features will become visible.
Gene
Gene
You are correct. But here it looks more like scale issue. The image is 106m x 117m and the small movement of -10mm that OP set is negligeble while rendering and gives that error. Here I have it set to -93 and just one scrollwheel zoom moves the circle from over to under the image: Maybe DraftRectangle.texture will work better but here I have bug with it so can't try.
It could be a scale issue, but it is not clear there is a bug. Instead there seems to be a simple display limitation. Under some conditions of z-shift and viewing tilt I was able to get "z-fighting", which means the display function treats the ImagePlane and the Circle to be in the same plane. If I set a much larger z-offset for the ImagePlane then there is no problem.
There may be some adjustment in the preferences, but I do not know where. In any case the effect is probably only visual, although confusing.
The screenshots below were all made with the same z-offset.
Gene
Gene
Be sure that in Properties the make face function is false
- benjaminwharton
Thanks all for the responses.
It seems like it might then be the result of precision issues since I'm using such a large scale for the ImagePlane.
