How to change units in FreeCAD? (forRadius less than 0.01mm)
oldestfox
Re: How to change units in FreeCAD? (forRadius less than 0.01mm)
Postby oldestfox » Sat Jul 13, 2013 8:50 pm
And if an American had actually stepped up to do the work, FreeCAD would already support US/imperial units.
Yes, it is sad. :cry: Believe me when I say that if I knew how to program, I would be in the top 5 developers working on this project.
NormandC
Postby NormandC » Sat Jul 13, 2013 9:04 pm
I hear you. I'm no programmer either, which is why I try to help the FreeCAD project in other ways.
oldestfox
Postby oldestfox » Sat Jul 13, 2013 9:26 pm
Maybe in the future when I know how to use FC, I will be able to offer help to the newcomers. Just depends on how well I learn it, myself.
btw... I submitted a feature request for simply increasing precision, *not* implementation of a US/Imperial system.
NormandC
Postby NormandC » Sat Jul 13, 2013 10:05 pm
Direct link: https://sourceforge.net/apps/mantisbt/f ... hp?id=1178
Wise choice. You run much higher chances of it being addressed in a timely manner. ;)
danielfalck wrote:We often times work with dimensions/tolerances in the .002mm or smaller range (grinding precision cylindrical features). I'm going to guess that there a lot of folks in the scientific world out there using much smaller units than that. Maybe adding a preferences feature to the dialogs in Sketcher that allows any reasonable amount of precision to the right of the decimal point would be good- if it doesn't cause the constraints engine to crash.
Actually in the sketcher you can already use 4 digit values in the small pop up dialog, even though only 2 digit show in the model view. It's only in Task Panel entry fields for Part Design features that you can't. I would think that it would be a pretty straightforward change.
bejant
Postby bejant » Sat Jul 20, 2013 10:34 pm
Here's a link to a .pdf converting inches (by sixteenths) to mm to 2 decimal places in the event someone finds it useful.
https://dl.dropbox.com/s/k1ybabd3g654eh ... places.pdf
tkin
Postby tkin » Sun May 03, 2015 7:19 pm
NormandC wrote:
jmaustpc wrote:As of right now, from a GUI users perspective one can not adjust either the units or the maximum precision (number of decimal places) of the the gui input fields.
This is not entirely true in v0.13......
Does this still hold true for v0.15.... I follow the step by step instructions but never seen any change in the property field?
Reason: Fixed quote
bejant
Postby bejant » Mon May 04, 2015 3:24 am
tkin wrote:Does this still hold true for v0.15....
No, you can change it if you navigate to Edit > Preferences > General (icon in left pane) > Units (tab in right pane) and change the "Number of Decimals" property. You can also change the Units, it's just above the "Number of Decimals".
voikovi
Postby voikovi » Thu Nov 28, 2019 11:05 pm
I also think it will be cool to have options to change units to micrometers (um) and to be able to do simulation on small devices like MEMS.
