Maximum number of objects? A more elegant way to group them?
daidalosnet
Post by daidalosnet »
I have a cylinder(hole in a box) and need around 250,000 copies of the same object, neatly arragned in an array.
I tried to use this macro:
http://sourceforge.net/apps/mediawiki/f ... _ArrayCopy
to copy the object, but FreeCAD always crashes and I think 250000 objects are
simply way to much for this program.
Is there a simpler way to group these objects, since it's a periodic array? I don't want to create 250000 objects by hand ; )
Thanks!
shoogen
Re: Maximum number of objects? A more elegant way to group them?
Post by shoogen »
please only use one feature
so instead of assigning the newshape to a new feature, you could fuse all the shapes together.
oldshape=None
        for column in range(u[0]):
            for row in range(v[0]):
                if (column != 0) or (row != 0):
                    delta = FreeCAD.Vector(column*u[1],row*v[1],0)
                    newshape = sel.Shape.copy()
                    newshape.translate(delta)
                    if oldshape is not None:
                       oldshape=oldshape.fuse(newshape)
                    else:
                       oldshape=newshape
          newobject = FreeCAD.ActiveDocument.addObject("Part::Feature",name)
          newobject.Shape = oldshape
daidalosnet
Thanks for your answer! But I'm afraid I'm not a good programmer. I tried to replace the if-else statement in the linked macro by your modified if-else statement.
Could you maybe post the complete macro with the right placement of your modification?
