[Solved] Part Design Part missing "Origin" feature
Will2
Post by Will2 »
I've just been working on a new file and made quite a bit of progress between saves so I don't have a backup save without this issue.
Something happened and I managed to delete the "Origin" feature in a Part Design part (the container that holds the X, Y, Z planes and axis). Is there a way to get this back? It not being there seems to have broken a few things such as any time a sketch is moved.
OS: Ubuntu 18.04.2 LTS
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.15rc1
Qt version: 5.9.5
Locale: English/Canada (en_CA)
Re: Part Design Part missing "Origin" feature
I only know of two ways, and none of them is really fun.
1.) Fast, but no guarantee for success:
- Create another file with a similar body.
- unzip both files or use Tools->Project utility to unpack.
- Look through Document.xml in both files, search for "Origin" and try to restore it.
- repack the zip file
- open in FreeCAD and perforem a full recompute
2.) Slower but safer
- Create a new body,
- transfer everything from the old body into the new
- If you don't succeed to transfer the features you almost always can reuse the sketches.
- rebuild dependencies to other bodies
kisolre
Post by kisolre »
There is something buggy here. I just tried to delete Origin and all its components and FreeCAD refuses to do so. On a plane that has sketches it warns for the dependency but then nothing happens. So it should not be possible to remove Origin. And when it happens there is a bug somewhere. To bad that it is not easily reproducible.
Of course it's a bug. I guess it occurs in connection with some undos, where the body is restored, but not the origin.
DeepSOIC
Post by DeepSOIC »
Will2 wrote: Fri Mar 29, 2019 12:13 am Is there a way to get this back?
origin = App.ActiveDocument.addObject('App::Origin', 'Origin')
App.ActiveDocument.Part.Origin = origin #replace "Part" with the internal name of your Part.
DeepSOIC wrote: Fri Mar 29, 2019 10:18 am
Faster than my fast way and safer than my safe way :) .
Will2
Post by Will2 »
I used DeepSOIC's method and it worked right away, I think it's all good now, thank you very much! It may help track down the bug but I believe this happened around the time I selected all the features of a particular part and hit "Duplicate selected object" to make a copy of it. Though I don't have any other information other than that currently. I believe I did an "undo" after the duplicate because I made a mistake in it. I could not duplicate the same problem after I fixed the file.
Re: [Solved] Part Design Part missing "Origin" feature
Post by NormandC »
Will2 wrote: Fri Mar 29, 2019 12:13 amPart Design Part
The Part container is not a PartDesign element. It's a general "standard" element. Its toolbar icon is found in *all* workbenches along with the Group icon, not only in PartDesign. It was in PartDesign only in the very beginning of 0.17 development, but it was changed nearly 2 years ago.
Std Part
If you look for this command in the source code, you will not find it in the PartDesign workbench but in /src/Gui.
https://github.com/FreeCAD/FreeCAD/sear ... q=Std_Part
Will2
Post by Will2 »
NormandC wrote: Fri Mar 29, 2019 5:01 pm
Std Part
Good point. Though maybe I'm doing something wrong. I've been mostly using the blue "body" icon and not the yellow "part" icon. I was confused when I first started using the part design workbench and I guess I just stuck to using the blue "body" icon.
davidhbrown
Post by davidhbrown »
Thank you! Still working great in version 20.26858 :-) I managed to need this after having deselected too many things when copying a part body to another document.
One tweak I'm not sure was necessary... I changed the second addObject() parameter from 'Origin' to 'Origin001' because there was already a body with an "Origin" in the document.
