[Implemented] Ticket #3923 - change order in tree view
bernd
Post by bernd »
If new groups or objects are added to the document they will be at the end of the tree view. Is it somehow possible to change the order of the tree view elements (I am interested in the first level only) manually? Attached a screen. I would like to move the "Aufhaenger-extrahiert" to the top above "hilfskoerper-zwischenstufen" and "FB Stahltreppe alle teile" between "Fusion001" and "Analysis"
bernd
Reason: This feature has been implemented in v0.20dev
Chris_G
Re: change order in tree view
Post by Chris_G »
There a "hack" way :
- create a group
- put all the objects in it, in the desired order
- delete the group
I used this technique until I realised, that it does not survive save/reload :( .
yorik
Founder
Post by yorik »
I'd like to discuss this question too at some point... Obviously we'll need Werner's opinion.
The list of objects in a FreeCAD document is apparently just a simple array https://github.com/FreeCAD/FreeCAD/blob ... .cpp#L2638 so in theory, it seems possible to remove an item from it and reinsert it at another place. AFAICS the tree is simply reflecting directly the array order
I tried this in the Path WB in the past, you can reorder objects inside a group (Path Compound): https://github.com/FreeCAD/FreeCAD/blob ... .cpp#L2638 and it seems pretty stable...
Maybe we could try? Add a couple of methods to the FreeCAD document to move an object in the stack, and see what happens :?:
bernd
Post by bernd »
since we have hundreds of messages each day especially in help, I sent him a message with a link to this topic.
cheers bernd
Founder
Post by wmayer »
IMO the easiest way would be to only change the tree view directly and do not touch the order of objects inside the document. To make the order of items in the tree view persistent the GuiDocument.xml can be extended to also store this order.
bernd
Post by bernd »
wmayer wrote: Fri Mar 29, 2019 3:35 pm IMO the easiest way would be to only change the tree view directly and do not touch the order of objects inside the document. To make the order of items in the tree view persistent the GuiDocument.xml can be extended to also store this order.
seams reosnable to me too, issue #3923
freecad-heini-1
Post by freecad-heini-1 »
bernd wrote: Tue Apr 02, 2019 11:07 am
I asked more or less the same question in August 2013:
https://forum.freecadweb.org/viewtopic. ... 220#p34220
With some strange answers.
Founder
Post by wmayer »
freecad-heini-1 wrote: Tue Apr 02, 2019 12:57 pm https://forum.freecadweb.org/viewtopic. ... 220#p34220
What you asked there is something different because it has an impact on the result when you change the order of operations. Something similar exists in PD (since v0.17) where for a body you can change the position of a feature. It is not yet very robust but it's a start.
What has been asked here -- unless I have understood something wrong -- is a pure GUI thing without any impact on any operations.
kisolre
Post by kisolre »
I dont know how DragDrop is realized but now it forbids dragging from one container(Document, Part, Group) to itself. If just this was possible it would be easy to rearange objects in reverse order - move object to end of container tree.
