[Solved] The mysterious "Pad:Result has multiple solids. This is not supported at this time."
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
I will attach three files below. I am trying to pad enigma to 6.35mm. When I try to do this, I am met with the error "Pad:Result has multiple solids. This is not supported at this time". I attached the abomination file to show what happens when the circle is deleted. I have encountered this error before. It happens when I attach a sketch to the face of an object in order to create a modified profile using the reference tool in sketch. It always goes away after I detach it though. For some reason it isn't going away, not even when the reference object is deleted and the sketch copied to a new file. Any ideas?
OCC version: 7.2.0
- Copy.FCStd
- (7.94 KiB) Downloaded 203 times
- New enigma.FCStd
- (56.87 KiB) Downloaded 139 times
- abomination.FCStd
- (21.76 KiB) Downloaded 137 times
Reason: added [Solved] to topic title
Re: The mysterious "Pad:Result has multiple solids. This is not supported at this time."
You seem to have doubled at least parts of your sketch, e.g. is line3 identical to line13, line 4 to line14.
Beyond that I don't see why you need the points.
Hi, Chrisb is right. There are some lines drawn double, I discovered 4 or 5. After deleting them in the sketch the Pad function works perfect. The Validation function in sketcer workbench helps with finding the doubles.
The file I checked is abomination.FCstd
You are both right. Thank you for the extra eyes.
Re: [Solved] The mysterious "Pad:Result has multiple solids. This is not supported at this time."
I got an idea and try draw it, base was success ( only few errors ), but then i try build next layer (from base to up) it generates this error, so i start over and over, same result every time... ....but when select "reversed" or "symmetric to plane" at Pad parameters, it works. hope this helps someone... for me, it is easier and lots faster to make model from cardboard or sheet metal and try idea that way.
In part design the pad has to produce a single solid once it's added to the body. Think of it like an ant is crawling on the model. The ant must be able to get to any place on the model from any place on the model without needing to jump, not even a tiny bit. The ants unionized and demanded this, so now we have to deal with it or else they would not come to any more of our picnics.annoyed wrote: ↑Wed Jul 10, 2019 9:49 pm I got an idea and try draw it, base was success ( only few errors ), but then i try build next layer (from base to up) it generates this error, so i start over and over, same result every time... ....but when select "reversed" or "symmetric to plane" at Pad parameters, it works. hope this helps someone... for me, it is easier and lots faster to make model from cardboard or sheet metal and try idea that way.
- wandererfan
I don't like this message. It was phrased this way because there was a possibility that multiple solids might be supported some time in the future.
I'd like to change it to something like "Invalid result. Not a single contiguous solid. Check sketch." That would at least give the user a clue of what the problem is.
I'll even volunteer to remove the message if multiple solid results are ever supported.
Werner has once implied that this restriction might indeed be removed someday. Until then the message can well be changed.
I vote for removing it if it can be done, or at least have a preference where if you don't want the restriction you don't have to live with it. I don't think it's an OCC restriction because multiple solids works with Part:Extrude, which I presume to be based on the same OCC algorithm. I think the preference would be better, then if some new feature comes in where you must have that preference turned off to use the new feature, then the user can make that decision at that time.
- wandererfan
The issue isn't that Sketch + Pad(etc) can't/won't make a multi part solid.TheMarkster wrote: ↑Thu Jul 11, 2019 6:19 am I don't think it's an OCC restriction because multiple solids works with Part:Extrude, which I presume to be based on the same OCC algorithm.
The problem comes later in the feature chain when something expecting a single part solid receives a multi part solid and doesn't know what to do with it. Then the model breaks mysteriously.
