[BUG?] Negative numbers in feet/inches interpreted wrong
metatheorem
Postby metatheorem » Wed Apr 03, 2019 2:14 am
I am seeing some strange behavior when working in feet and inches in the "Building US" units.
FreeCAD is interpreting combined foot/inch values that are negative as expressions and this is giving me incorrect results.
For example, say I want to move an object one foot and four inches in the negative X direction. If I use the Draft Move tool and type this in: -1' 4" for the second point, the program will add these numbers together (-12" + 4"), moving only eight inches (-8"). I can even observe this happening by moving the focus to/from the entry field.
Is this a known issue? Is there a way to force the program not to interpret these entries as expressions?
Thanks
OS: Linux
Version: 0.18.Unknown
Build type: Unknown
Python version: 2.7.15
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
openBrain
Re: [BUG?] Negative numbers in feet/inches interpreted wrong
Postby openBrain » Wed Apr 03, 2019 2:15 pm
Confirmed here with latest 0.18 under Windows 7.
This behavior exists :
  • Whatever is the base unit selected => You can enter -1'4" value when working in mKs, you'll get the same result
  • Whatever is the unit used in the value => You can enter -1m500mm and get same kind of result
The only way at now is entering -1'-4" but doesn't sound very natural.
@metatheorem : as a sidenote, you can read from this thread if you'd like to compile with Qt5 and OCCT7+ ;)
Postby chrisb » Wed Apr 03, 2019 3:30 pm
This doesn't work either, because it is parsed twice: once when entering the value and a second time when confirming the dialog.
openBrain
Postby openBrain » Wed Apr 03, 2019 4:10 pm
]This doesn't work either, because it is parsed twice: once when entering the value and a second time when confirming the dialog.
Ouch. I admit that I just tried by changing a position in the comboview. Indeed the case described by OP is another one. ;)
I can't try now but what about using something like -(1'4") ?
Postby chrisb » Wed Apr 03, 2019 4:33 pm
I see you had all the ideas which I had :) , but no, brackets are not accepted by the input field :cry: .
openBrain
Postby openBrain » Wed Apr 03, 2019 5:55 pm
I tried some various things and can't find a decent workaround. Definitely sounds as a real bug...
Geoplace
Postby Geoplace » Thu Apr 04, 2019 10:25 pm
metatheorem
Postby metatheorem » Thu Apr 04, 2019 10:51 pm
I've opened a bug for this: https://www.freecadweb.org/tracker/view.php?id=3925.
@openBrain: Thanks, I'm working off of a repo build right now, but will probably build if I find the time soon...
