OS: Linux Mint 19.1 Tessa
Version: 0.17.13541 (Git) AppImage
Build type: None
Branch: releases/FreeCAD-0-17
Python version: 2.7.6
Qt version: 4.8.6
I'm beginning a model made up of several parts that I want to be independent of one another. All together, it's a relatively simple thing - a latch for my Dad's rolator walker to hold it closed when it's folded up. It will consist of three bushings and a bar, plus part of the halves of the bench to locate things. Ultimately, I'll want to produce some drawings to take to the shop to fabricate the parts.
The question is this: to keep the parts separate from one another in the model file, do I need to create an new body for each new part? I've had some trouble finding info in the documentation describing the concept of operations for FreeCad in this respect.
Thanks.
Bill Lugg
Building a model with several parts
Re: Building a model with several parts
You are absolutely correct. A PartDesign Body is a contiguous solid, like a nail, a bolt, a cogwheel, etc. Once you put these together, then you have an "assembly". Currently FreeCAD doesn't have an official assembly workbench, so you just create Bodies and arrange them together in space. You can put these bodies inside a Std Part container, and that would be your assembly, so to speak. Then you use the TechDraw Workbench to produce 2D drawings, and send these to the shop for manufacturing.
If you'd like to test some real assembly capabilities, there is the A2plus Workbench. This is not officially part of FreeCAD (it's one of many external workbenches) but works quite well for many cases. In the future FreeCAD will probably adopt parts of this workbench and others that are in development in order to have an officially supported assembly workbench.
Also, FreeCAD 0.18 was just released, so grab that for the latest functionality.
This is something I've been thinking of doing, we need to have several "assembly" tutorials, one with a "pseudo-assembly" work flow with only FreeCAD "core" and multiple PD Bodies in a single file, another with the A2+ assembly add-on, and so on. But I'm already struggling with my current list of tasks...
+1NormandC wrote: ↑Wed Apr 10, 2019 2:48 am we need to have several "assembly" tutorials, one with a "pseudo-assembly" work flow with only FreeCAD "core" and multiple PD Bodies in a single file, another with the A2+ assembly add-on, and so on. But I'm already struggling with my current list of tasks...
I could do the pseudo assembly, but here it will take some time too.
i think this would be a good layout:
1. Build solid (body) and show/explain why operations resulting in multi solids fail. show sketch based on face vs sketch based on plane.
2. Position several bodies relative to each other, manual placement, part container and nested parts
3. revisit 1. but use spreadsheet reference for dimensions
4. revisit 2 but with spreadsheet references for placements.
5. A2Plus tutorial
6. ASM3 tutorial
5. A2Plus tutorial
6. ASM3 tutorial
- HarryGeier
I think i should make a new video dealing with simple multi part structures.
I put this on my agenda.
For static structures i normally just use multi bodies attached to each other or to the main body with shapebinders and datum planes on them.
2 samples:
2 samples:
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
- miniellipse
+1HarryGeier wrote: ↑Wed Apr 10, 2019 6:08 am I think i should make a new video dealing with simple multi part structures.
