Freecad closes when the document is saved (Solved)
dcapeletti
Postby dcapeletti » Wed Apr 10, 2019 10:07 am
Hi, when I open the attachment and try to save it, freecad closes. I hope you can help me.
Thanks
OS: Debian GNU/Linux 9 (stretch)
Version: 0.19.16207 (Git) AppImage
Hash: 741533941c67da2f721bf1b7c2d55c987fd22a0c
Python version: 3.6.7
Qt version: 5.6.2
Locale: Spanish/Argentina (es_AR)
./FreeCAD_0.19.16207_Conda_Py3Qt5_glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCAYp0ST5
FreeCAD 0.19, Libs: 0.19R16207 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Sheet Metal workbench loaded
Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
** (FreeCAD:9746): WARNING **: 07:03:30.295: invalid source position for vertical gradient
No extension found of type 'Gui::ViewProviderLinkObserver'
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x33060) [0x7f1e80a76060]
#1  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x3e9771) [0x7f1e65869771]
#2  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x9aabe) [0x7f1e6551aabe]
#3  0x7f1e84a40232 in SoMarkerSet::GLRender(SoGLRenderAction*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x662
#4  0x7f1e84901340 in SoSeparator::GLRenderBelowPath(SoGLRenderAction*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0xd0
#5  0x7f1e84901340 in SoSeparator::GLRenderBelowPath(SoGLRenderAction*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0xd0
#6  0x7f1e848d3bed in SoAnnotation::GLRenderBelowPath(SoGLRenderAction*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x8d
#7  0x7f1e846b5414 in SoAction::traverse(SoNode*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x54
#8  0x7f1e8489980f in SoChildList::traverse(SoAction*, int, int) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x11f
#9  0x7f1e849054f6 in SoSwitch::doAction(SoAction*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x2a6
#10  0x7f1e849007e8 in SoSeparator::GLRenderInPath(SoGLRenderAction*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0xd8
#11  0x7f1e849007e8 in SoSeparator::GLRenderInPath(SoGLRenderAction*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0xd8
#12  0x7f1e849007e8 in SoSeparator::GLRenderInPath(SoGLRenderAction*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0xd8
#13  0x7f1e846b5414 in SoAction::traverse(SoNode*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x54
#14  0x7f1e846bc6f5 in SoGLRenderAction::beginTraversal(SoNode*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0xb5
#15  0x7f1e846b507f in SoAction::apply(SoPathList const&, int) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x1ff
#16  0x7f1e846bbc4b in SoGLRenderActionP::renderSingle(SoNode*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x27b
#17  0x7f1e846bc038 in SoGLRenderActionP::render(SoNode*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0xf8
#18  0x7f1e846bc6d4 in SoGLRenderAction::beginTraversal(SoNode*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0x94
#19  0x7f1e846b56b9 in SoAction::apply(SoNode*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libCoin.so.4.0.0+0xb9
#20  0x7f1e86f40a2b in Gui::SoBoxSelectionRenderAction::apply(SoNode*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x1b
#21  0x7f1e86fd5892 in Gui::View3DInventorViewer::renderToFramebuffer(QOpenGLFramebufferObject*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x1c2
#22  0x7f1e86fd5e4b in Gui::View3DInventorViewer::imageFromFramebuffer(int, int, int, QColor const&, QImage&) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x17b
#23  0x7f1e86dcdecb in Gui::Thumbnail::SaveDocFile(Base::Writer&) const from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x62b
#24  0x7f1e86202af7 in Base::ZipWriter::writeFiles() from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADBase.so+0x87
#25  0x7f1e865ea5b2 in App::Document::saveToFile(char const*) const from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADApp.so+0x3b2
#26  0x7f1e865eb176 in App::Document::save() from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADApp.so+0x146
#27  0x7f1e86649902 in App::DocumentPy::save(_object*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADApp.so+0x32
#28  0x7f1e86649a87 in App::DocumentPy::staticCallback_save(_object*, _object*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADApp.so+0x27
#29  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(_PyCFunction_FastCallDict+0x18e) [0x7f1e85c70c1e]
#30  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(+0x1650da) [0x7f1e85d0a0da]
#31  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(_PyEval_EvalFrameDefault+0x3002) [0x7f1e85d0d902]
#32  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(+0x164cde) [0x7f1e85d09cde]
#33  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(PyEval_EvalCodeEx+0x6d) [0x7f1e85d0a30d]
#34  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(PyEval_EvalCode+0x3b) [0x7f1e85d0a35b]
#35  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(PyRun_StringFlags+0x92) [0x7f1e85d45772]
#36  0x7f1e861a32d4 in Base::InterpreterSingleton::runString(char const*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADBase.so+0x54
#37  0x7f1e86de624a in Gui::Command::doCommand(Gui::Command::DoCmd_Type, char const*, ...) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x12a
#38  0x7f1e86d8e623 in Gui::Document::save() from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x53
#39  0x7f1e86fcda71 in Gui::View3DInventor::onMsg(char const*, char const**) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x591
#40  0x7f1e86d72257 in Gui::Application::sSendActiveView(_object*, _object*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x57
#41  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(_PyCFunction_FastCallDict+0x18e) [0x7f1e85c70c1e]
#42  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(+0x1650da) [0x7f1e85d0a0da]
#43  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(_PyEval_EvalFrameDefault+0x3002) [0x7f1e85d0d902]
#44  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(+0x164cde) [0x7f1e85d09cde]
#45  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(PyEval_EvalCodeEx+0x6d) [0x7f1e85d0a30d]
#46  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(PyEval_EvalCode+0x3b) [0x7f1e85d0a35b]
#47  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libpython3.6m.so.1.0(PyRun_StringFlags+0x92) [0x7f1e85d45772]
#48  0x7f1e861a32d4 in Base::InterpreterSingleton::runString(char const*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADBase.so+0x54
#49  0x7f1e86de624a in Gui::Command::doCommand(Gui::Command::DoCmd_Type, char const*, ...) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x12a
#50  0x7f1e86dea44c in Gui::Command::invoke(int) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x4c
#51  0x7f1e81d7e8d1 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Core.so.5+0x2c1
#52  0x7f1e826f9372 in QAction::triggered(bool) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0x32
#53  0x7f1e826fc09d in QAction::activate(QAction::ActionEvent) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0x5d
#54  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5(+0x25952d) [0x7f1e827fe52d]
#55  0x7f1e827fe664 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0xd4
#56  0x7f1e828c564a in QToolButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0xa
#57  0x7f1e8274573a in QWidget::event(QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0x96a
#58  0x7f1e828c5729 in QToolButton::event(QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0x69
#59  0x7f1e82702c6c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0x9c
#60  0x7f1e82707b5d in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0xc6d
#61  0x7f1e86dc1541 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x41
#62  0x7f1e81d54425 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Core.so.5+0x75
#63  0x7f1e82706860 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0x1a0
#64  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5(+0x1b9cd1) [0x7f1e8275ecd1]
#65  /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5(+0x1bc2c3) [0x7f1e827612c3]
#66  0x7f1e82702c6c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0x9c
#67  0x7f1e827072ea in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Widgets.so.5+0x3fa
#68  0x7f1e86dc1541 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x41
#69  0x7f1e81d54425 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Core.so.5+0x75
#70  0x7f1e820f87db in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Gui.so.5+0x40b
#71  0x7f1e820f9f75 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Gui.so.5+0x115
#72  0x7f1e820db74b in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Gui.so.5+0x7b
#73  /tmp/.mount_FreeCAYp0ST5/usr/lib/libQt5XcbQpa.so.5(+0xa05d0) [0x7f1e78adb5d0]
#74  /tmp/.mount_FreeCAYp0ST5/usr/lib/libglib-2.0.so.0(+0x569be) [0x7f1e7ba329be]
#75  /tmp/.mount_FreeCAYp0ST5/usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x33) [0x7f1e7ba33826]
#76  /tmp/.mount_FreeCAYp0ST5/usr/lib/libglib-2.0.so.0(+0x57a0b) [0x7f1e7ba33a0b]
#77  /tmp/.mount_FreeCAYp0ST5/usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x4a) [0x7f1e7ba33acf]
#78  0x7f1e81da598c in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Core.so.5+0x5c
#79  0x7f1e81d5253b in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Core.so.5+0xfb
#80  0x7f1e81d5a466 in QCoreApplication::exec() from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libQt5Core.so.5+0x86
#81  0x7f1e86d5e3ec in Gui::Application::runApplication() from /tmp/.mount_FreeCAYp0ST5/usr/bin/../lib/libFreeCADGui.so+0x16bc
#82  /tmp/.mount_FreeCAYp0ST5/usr/bin/FreeCAD(main+0x6c9) [0x403829]
#83  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1) [0x7f1e80a632e1]
#84  /tmp/.mount_FreeCAYp0ST5/usr/bin/FreeCAD() [0x404699]
/tmp/.mount_FreeCAYp0ST5/AppRun: línea 10:  9746 Violación de segmento  ${HERE}/usr/bin/FreeCAD "$@"
Bielle.fcstd
(88.13 KiB) Downloaded 8 times
openBrain
Re: Freecad closes when the document is saved
Postby openBrain » Wed Apr 10, 2019 11:48 am
Can you reproduce with a stable release of FreeCAD ? Say 0.17 or 0.18.
dcapeletti
Postby dcapeletti » Fri Apr 12, 2019 10:38 pm
Hello, in version 0.17, freecad does not close. There are no errors. Thanks
Postby chrisb » Fri Apr 12, 2019 11:05 pm
No problem here with 0.19:
OS: macOS 10.13
Python version: 3.7.2
Qt version: 5.6.2
bejant
Postby bejant » Sat Apr 13, 2019 3:06 am
I don't have a problem saving the file either. Running the macro ForceRecompute does alter the model (I'm guessing that changing topological naming and Links To External Geometry are coming back to bite you):
and also shows that there is an error in Sketch004. Constraint 26 is Redundant and should be deleted (instead use a Coincident Constraint at the 3 endpoints there).
Attached is the saved file, after I fixed Sketch004.
20190413a-Bielle.FCStd
(69.58 KiB) Downloaded 7 times
OS: Ubuntu 18.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.15rc1
Qt version: 5.9.5
Postby chrisb » Sat Apr 13, 2019 7:39 am
If noone else has such problem it is time to try resetting the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
I see that you have additonal workbenches installed. So renaming the config folder to get a plain vanilla setup could make things clearer.
kisolre
Postby kisolre » Sat Apr 13, 2019 7:42 am
I little more fixed file :)
2019.04.13_kiss_Bielle.FCStd
(60.19 KiB) Downloaded 6 times
dcapeletti
Postby dcapeletti » Sat Apr 13, 2019 10:31 am
In the new file they have sent, it still causes problems in version 0.19, but not in version 0.17. Thanks
dcapeletti
Postby dcapeletti » Sat Apr 13, 2019 10:37 am
I deleted the files user.cfg and system.cfg and now everything runs smoothly in both versions.
