I have those 2 constraints (4mm)
I would like to be able to change both at the same time by changing 1 value only, like if there had an "equal" constraint between them.
Sorry if I'm not clear I'm still a noob with freecad
Thanks for your help
"synchronize" constraints
Re: "synchronize" constraints
Hi
there are several solutions:
you draw 2 lines of construction (in blue), constrain equal, and size a single
- egalité.PNG (9.7 KiB) Viewed 747 times
Thanks for your answer !
Since my part is a rectangle, I ended up using diagonals
What do you think ?
Cheers
What do you think ?
Cheers
there is one of the several other solutions
- DeepSOIC
As long as both constraints are red, they can be tied with an expression (use f(x) blue button in value edit box, use something like Constraints.myLength). The constraint you refer to in an expression must have been given a name.
As of now, expressions involving blue constraints (reference dimensions) are not yet supported. Having support for them would give some awesome power, but it requires serious development effort. Your example features only red constraints, so it should work.
indeed, i'm stupid.
gonna use the other way then, thanks
Thank you this is perfect ! <3DeepSOIC wrote: ↑Wed Apr 10, 2019 12:11 pm As long as both constraints are red, they can be tied with an expression (use f(x) blue button in value edit box, use something like Constraints.myLength). The constraint you refer to in an expression must have been given a name.
