On Ubuntu 16.04, using the last freecad-daily ppa ( ...093?), I was getting a
message at startup saying something to the effect
"gitPython not available, using regular addon loader"
Other than this nagging message, freecad appeared to work normally.
But the annoyance level finally got high enough that I decided to address
this by installing the missing package.
After doing so, the gitPython message disappeared and everything seemed
still to be working ok. However, upon exiting freecad it spewed 28 error
messages at me.
[I know this is not the best error report. Bear with me. I don't have that install anymore. Hard evidence to follow.]
I uninstalled and reinstalled freecad with no change.
I downloaded this 0.19 version
OS: Ubuntu 16.04.6 LTS
Version: 0.19.16207 (Git) AppImage
Hash: 741533941c67da2f721bf1b7c2d55c987fd22a0c
Python version: 3.6.7
Qt version: 5.6.2
and it loads cleanly (it does tell me to look in the log file but
doesn't say where to find that file). 0.19 runs fine and exits cleanly.
I have today installed the new 0.18.1 stable ppa
Version: 0.18.1.
Python version: 2.7.12
0.18.1 behaves the same as the 0.18 freecad-daily it replaced. That is, it loads
without incident, seems to run fine but, upon exit, throws this alarming pile...
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f0e5ce514b0]
#1 0x7f0e5e1388da in QFontEngineX11FT::freeServerGlyphSet(unsigned long) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x1a
#2 0x7f0e5e140461 in QFontEngineFT::freeGlyphSets() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x91
#3 0x7f0e5e13887c in QFontEngineX11FT::~QFontEngineX11FT() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x1c
#4 0x7f0e5e1388a9 in QFontEngineX11FT::~QFontEngineX11FT() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x9
#5 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x3fd7d6) [0x7f0e5e06e7d6]
#6 0x7f0e5e13a209 in QFontEngineMultiFT::~QFontEngineMultiFT() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x9
#7 0x7f0e5e09bb26 in QTextEngine::resetFontEngineCache() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x66
#8 0x7f0e5e09d186 in QTextEngine::~QTextEngine() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x96
#9 0x7f0e5e0a8175 in QTextLayout::~QTextLayout() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x15
#10 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x86d4b4) [0x7f0e5e4de4b4]
#11 0x7f0e5d9212b1 in QObjectPrivate::deleteChildren() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x81
#12 0x7f0e5de8c2a2 in QWidget::~QWidget() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x332
#13 /usr/lib/python2.7/dist-packages/PySide/QtGui.so(+0x465641) [0x7f0e257e5641]
#14 0x7f0e5d9212b1 in QObjectPrivate::deleteChildren() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x81
#15 0x7f0e5de8c2a2 in QWidget::~QWidget() from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x332
#16 /usr/lib/python2.7/dist-packages/PySide/QtGui.so(+0x793f61) [0x7f0e25b13f61]
#17 /usr/lib/x86_64-linux-gnu/libshiboken-python2.7.so.1.2(+0xf2b5) [0x7f0e582042b5]
#18 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(+0xc8eb2) [0x7f0e5ea2deb2]
#19 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(+0x15d897) [0x7f0e5eac2897]
#20 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyDict_SetItem+0x7b) [0x7f0e5eac701b]
#21 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(_PyModule_Clear+0x16b) [0x7f0e5eb0376b]
#22 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyImport_Cleanup+0x28e) [0x7f0e5eac050e]
#23 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(Py_Finalize+0xfe) [0x7f0e5ea89e6e]
#24 0x7f0e5ef9e212 in Base::InterpreterSingleton::finalize() from /usr/lib/freecad-python2/lib/libFreeCADBase.so+0x12
#25 0x7f0e5f4c113f in App::Application::destruct() from /usr/lib/freecad-python2/lib/libFreeCADApp.so+0x19f
#26 freecad(main+0x7b1) [0x556681cce721]
#27 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f0e5ce3c830]
#28 freecad(_start+0x29) [0x556681ccf949]
Anyone have any clues?
p.s., where does freecad put its log files? I can't find any.
