I'm sure I'm doing something wrong. When exporting the attached file as a dxf for laser cutting, it creates a file appearing to have four copies of every entity. After tediously removing the seemingly duplicate entities, I am unable to produce complete polylines, which I presume means the entities are discontinuous. I've tried the drafting shape 2d view, but it doesn't maintain the involute faces in the projection, and when I enable tessellation, it produces a weird and unusable result.
Any help much appreciated.
OS: Debian GNU/Linux 9.7 (stretch) (XFCE/xfce)
Version: 0.18.15609 (Git)
Hash: a14af0f2bd26f980d71be80a799ee48127bc7619
Python version: 2.7.13
OCC version: 6.8.0.oce-0.17
Multiple entities in dxf export
- advance_small_gear.FCStd
- (116.11 KiB) Downloaded 32 times
- wandererfan
Re: Multiple entities in dxf export
The attached file seems to have splines on the teeth instead of straight lines. Is it closer to what you need?Chowderhead wrote: ↑Fri Apr 12, 2019 2:22 pm ...but it doesn't maintain the involute faces in the projection....
This version is almost prehistoric. OCC 7.3 is much better.OCC version: 6.8.0.oce-0.17
- advance_small_gear_New.dxf
- (128.23 KiB) Downloaded 32 times
Thanks for the reply. I'll update OCC.
Attached is what I see upon opening the file you provided. Not sure what's up.
- new.png (24 KiB) Viewed 1161 times
- wandererfan
Hmm, looks good in DraftSight... Let me dig some more.Chowderhead wrote: ↑Fri Apr 12, 2019 10:34 pm Attached is what I see upon opening the file you provided. Not sure what's up.
- wandererfan
Looks good in FreeCAD too;
OS: Linux Mint 19
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.15rc1
Qt version: 5.9.5
Try this FCStd file and let me know what you see.OS: Linux Mint 19
Qt version: 5.9.5
- advance_small_gear_Imported.FCStd
- (344.59 KiB) Downloaded 32 times
There are a lot of settings for DXF in FreeCAD. I went through some of them and experimented on the result.
I had to install it via the "tools menu...add-ons manager....workbenches tab...dxf library".
Interestingly, the "import splines as polylines" option seems not to work, i.e. splines were still imported.
Either create simple shapes or Draft WB Objects both work but create a sketch fails
OS: Kubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
you appear to be using the "legacy python importer" which does import your dxf file
and you appear to not be doing so.
Version: 0.18.1.
Qt version: 5.9.5
Thank you both for the replies. Installing the dxf library did the trick. I'm off to cut parts!
- wandererfan
