Export to dxf
Re: Export to dxf
Sorry - I thought I had done that.
Here it is
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Here it is
Qt version: 5.6.2
- roerich_64
Re: Export to dxf
You can find the preferences under Edit and then preferences: 1 click on 'edit' then the last point 'preferences'
2 click on 'Import-Export'
3 The Tab 'DXF' should be selected. You can select it when you click on it
Walter
Die Liebe wird siegen, denn sie ist unzerstörbar
- roerich_64
Re: Export to dxf
Next Step:
I have download your File and open it. I see this:
- roerich_64
Re: Export to dxf
To make the Sketch visible:
take one click on sketch036 and take the space bar on your keyboard:
Re: Export to dxf
Hi Roerich
Thank you.
I can see the drawing. Plus, I have attached my dxf preferences. I think they are OK…ha-ha who am I trying to convince. They maybe they may not be.
But still I cannot export to dxf
Dan
Thank you.
Dan
- Capture-2019-04-16-04.JPG (167.31 KiB) Viewed 800 times
- roerich_64
Re: Export to dxf
now you can directly export the sketch036 to DXF-Format:
To do this you have to select File - export: Then it opens a File-Manager: 1 Filemanager named 'Export-File'
2 you need the right File-Format
3 to select the right Fileformat click on the 'Drop-Down Bottom
Now you can select the correct Fileformat:
- roerich_64
Re: Export to dxf
The next step is to save the File:
1 the right file-format is selected
2 give them a name
3 click on safe
2 give them a name
3 click on safe
Re: Export to dxf
Hi Roerich
Here we go and here I fail
See the screen shots.
Ahhhhh
Dan
Ahhhhh
Dan
- Capture-2019-04-16-06.JPG (141.6 KiB) Viewed 788 times
- Capture-2019-04-16-05.JPG (104.72 KiB) Viewed 788 times
- roerich_64
Re: Export to dxf
Then, after a short time, it opens the preferences of 'Import-Export' automatically:
2 click on 'DXF' to select them
3 click 'OK'
Thats it
You should found the exported File in the folder you have selected in the 'Export-File' Filemanager.
1 'Import-Export' was automatically selected2 click on 'DXF' to select them
3 click 'OK'
Thats it
- roerich_64
Re: Export to dxf
Ok.
Now we have found your 'issue'
Deselect this point in preferences:
BR
Walter
BR
Walter
