Ticket #3953 - Unable to print (0.18 final)
benjaminwharton
Post by benjaminwharton »
I've just noticed that hitting ctrl+p or using "print" in the file menu doesn't do anything anymore. No print dialog, nothing. I've included a file as an example, although all you have to do is open a new document, draw something, and try printing it. I have no problem printing in previous versions.
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/France (fr_FR)
print me.FCStd
(3.77 KiB) Downloaded 77 times
Syres
Re: Unable to print (0.18 final)
Post by Syres »
When you state that you had no problem printing in previous versions were they Py2Qt4 builds, because I can't find any of my old Py3Qt5 builds that this worked in?
By the way with all logging set in Report View, there are two messages when trying to print:
QPrintDialog: Cannot be used on non-native printers
OS: Windows 7
Qt version: 5.6.2
Print dialog loads as expected, though I have never had any reason to use it using:
OS: Windows 7
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.14
OCC version: 7.2.0
benjaminwharton
Syres wrote: Thu Apr 18, 2019 5:22 pm When you state that you had no problem printing in previous versions were they Py2Qt4 builds, because I can't find any of my old Py3Qt5 builds that this worked in?
Sorry, I don't know much about snakes. :oops: Here's the information for the version that does work for me:
Version: 0.18.15938 (Git)
Hash: acdd4b097bbaf6d94bc09cf38f25924bd5d3e778
OCC version: 7.2.0
wandererfan
Post by wandererfan »
benjaminwharton wrote: Thu Apr 18, 2019 12:49 pm I've just noticed that hitting ctrl+p or using "print" in the file menu doesn't do anything anymore. No print dialog, nothing. I've included a file as an example, although all you have to do is open a new document, draw something, and try printing it.
We are talking about printing from the 3D view, right?
In these versions, the best print result I get from the 3D view is a blank page. Both TechDraw and Drawing print ok.
OS: Linux Mint 19
Python version: 2.7.15rc1
Qt version: 5.9.5
Locale: English/Canada (en_CA)
OS: Linux Mint 19
Version: 0.18.1.
Qt version: 5.9.5
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.16474 +1 (Git)
Build type: debug
Branch: LeaderLine
Hash: 0ff07ac6cadc2c83ccfb2a1280b66ec9ddfc75ca
Python version: 3.6.7
Qt version: 5.9.5
But in this version, I can print from the 3D view.
OS: Linux Mint 19 Tara (X-Cinnamon/cinnamon)
Version: 0.19.16486 (Git)
Build type: debug
Hash: bbd9fbf892879f27ab8a69841de37e91bf11d6f1
OCC version: 7.2.0
Qt5.9 vs Qt4.8??
benjaminwharton
wandererfan wrote: Thu Apr 18, 2019 11:31 pmWe are talking about printing from the 3D view, right?
Yes, or even from a TechView page.
wandererfan
benjaminwharton wrote: Fri Apr 19, 2019 12:37 am Yes, or even from a TechView page.
I can print or export PDF from TechDraw successfully in all the version listed above. I only have problems printing the 3D window.
Are you having problems printing from TechDraw and/or Drawing also?
jmaustpc
Post by jmaustpc »
Printing the 3d model view here worked with export to pdf and print preview from the file menu.
I just opened FreeCAD, new document, Part WB, default Part Cube and then File menu ... print preview (and I tried export to pdf), both seemed to work as expected.
I created a default techdraw page, inserted a top view, added a dimension, once again Export as PDF and print preview worked perfectly.
OS: Kubuntu 18.04.2 LTS
Version: 0.18.1.
Qt version: 5.9.5
benjaminwharton
wandererfan wrote: Fri Apr 19, 2019 12:24 pm
I tried TechDraw again just to be sure (and Drawing because why not) and it's the same log message that I get when trying to print the 3D view (QPrintDialog: Cannot be used on non-native printers)
wandererfan
benjaminwharton wrote: Fri Apr 19, 2019 3:15 pm I tried TechDraw again just to be sure (and Drawing because why not) and it's the same log message that I get when trying to print the 3D view (
OK, that's a different problem - I don't get that message.
I found a few posts on the internet about "cannot be used on non-native printers" but nothing specific to Win10. The resolution seems to be to move to a newer Qt5.x.
hinckel
Post by hinckel »
OS: openSUSE Tumbleweed (KDE//usr/share/xsessions/plasma5)
Version: 0.19.16502 (Git)
Build type: Unknown
Hash: 06962535fa9ff348acca1b893cc4239908fb8bae
Python version: 3.7.2
Qt version: 5.12.2
Coin version: 3.1.3
Can export and print pdf from Techdraw but not from Part Designs..
