Hi All,
I'm new to FC but tried to search the forums as well as watched few youtube tutorials to try to fix the issue myself without much success...
I have downlowded a design from thingsverse (a robot) but had to modify it to fit the servos I had. Basically, I deleted a cut note child ..
Then I started seeing multiple unexplained errors ... probably since the original author did not use names but left the auto naming and it got corrupted after mu child node delete...
The problem is that when I put my mouse on the error it just show "error" without much info...
How do I progress from here ... Is there some additional console where more info is given ?
Can anyone take a quick look and suggest places where I can read and solve the problem ?
Any other suggestion ?
Thanks!
Lior
P.S. the model is here:
https://drive.google.com/open?id=1FGTQD ... vvf1H5QINo
OS: Debian GNU/Linux 9.8 (stretch)
Version: 0.17.13541 (Git) AppImage
Build type: None
Branch: releases/FreeCAD-0-17
Python version: 2.7.6
Qt version: 4.8.6
Strange errors after child node delete
- 20190419_131451.resized.jpg (55.22 KiB) Viewed 372 times
Re: Strange errors after child node delete
Hi Lior, welcome to the forum.
This might turn out to be worse than expected. Usually you can mark the whole file for recomputing (right mouse button) and after executing the recompute the mouse over message shows you the error.
Additionally I recommend to redirect in the preferences the errors to report view and show the report view (View->Panels->Report view).
I have tried to perform a recompute which makes my FreeCAD crash.
OS: macOS 10.13
Version: 0.19.16398 (Git)
Hash: 847035cbd227d1f7554a494c3cfe5fa8942f2b7c
Python version: 3.7.3
Qt version: 5.6.2
OS: macOS 10.13
Qt version: 5.6.2
You use an old design built with a version of FreeCAD prior to 0.17. In the meantime the structure has changed, all PartDesign sketches and features now live in a body.
Additionally the model has taken advantage of a bug in the old version, i.e. it has padded a non contiguous sketch to multiple solids. That is the error you are facing here.
If you rebuild the model with using Part->Extrude instead of Pad you may have success. You can either copy the sketches and rebuild things manually or you can try in OpenSCAD workbench to replace an inner element of the tree. (Cannot test myself, OpenSCAD is currently not working here).
Thanks for the leads ! Will go down the rabbit hole ...
Lior
Lior
Can you give the thingiverse link? If that is the only change you need it might be easy to work with the STL.
Hi
It's indeed from a FC 3 years ago
https://github.com/owenlab/poorkame
As for working on the STL itself, it will be problematic since I need to strech the model itself for bigger batteries so it is not just a simple pad (which I would have dome easily in openscad) ... I was also looking to use that opportunity to learn FC so I will continue trying to fix the model for version .19 ..
My current path is using getting rid of the pad and using part->extrude ... I'm still trying to remove a pad from the tree without breaking the whole naming structure ..
Since you try to learn FreeCAD it might be easy to design the parts from scratch using the originals as reference.
To add to that, and to prevent any misconceptions, the replace element tool has no relationship with the external OpenSCAD program. In fact, most of the tools in the OpenSCAD workbench do not require installation of OpenSCAD to work.
