Seem got what you described...
[paullee@localhost squashfs-root]$ ./AppRun
/home/paullee/Downloads/FreeCAD_0.19.16291_Conda_Py3Qt5_glibc2.12-x86_64/squashfs-root
FreeCAD 0.19, Libs: 0.19R16291 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
(FreeCAD:7238): Gtk-WARNING **: 02:07:45.762: GModule (/usr/lib64/gtk-2.0/2.10.0/immodules/im-ibus.so) initialization check failed: GLib version too old (micro mismatch)
(FreeCAD:7238): Gtk-WARNING **: 02:07:45.762: Loading IM context type 'ibus' failed
(FreeCAD:7238): Gtk-WARNING **: 02:07:45.766: GModule (/usr/lib64/gtk-2.0/2.10.0/immodules/im-ibus.so) initialization check failed: GLib version too old (micro mismatch)
(FreeCAD:7238): Gtk-WARNING **: 02:07:45.767: Loading IM context type 'ibus' failed
(FreeCAD:7238): Gtk-WARNING **: 02:07:45.837: GModule (/usr/lib64/gtk-2.0/2.10.0/immodules/im-ibus.so) initialization check failed: GLib version too old (micro mismatch)
(FreeCAD:7238): Gtk-WARNING **: 02:07:45.837: Loading IM context type 'ibus' failed
Geodat WB: Cannot import module named cv2
Geodat WB: Cannot import module named gdal gdalconst
loading A2plus on operating system 'LINUX'
** (FreeCAD:7238): WARNING **: 02:08:19.129: invalid source position for vertical gradient
File "/home/paullee/Downloads/FreeCAD_0.19.16291_Conda_Py3Qt5_glibc2.12-x86_64/squashfs-root/usr/Mod/Arch/ArchMaterial.py", line 299, in onChanged
val = str(obj.Color[:3])
<class 'RecursionError'>: maximum recursion depth exceeded while getting the str of an object
Fatal Python error: Cannot recover from stack overflow.
Current thread 0x00007fb1bb9d7280 (most recent call first):
File "/home/paullee/Downloads/FreeCAD_0.19.16291_Conda_Py3Qt5_glibc2.12-x86_64/squashfs-root/usr/Mod/Arch/ArchMaterial.py", line 265 in onChanged
File "/home/paullee/Downloads/FreeCAD_0.19.16291_Conda_Py3Qt5_glibc2.12-x86_64/squashfs-root/usr/Mod/Arch/ArchMaterial.py", line 270 in onChanged
File "/home/paullee/Downloads/FreeCAD_0.19.16291_Conda_Py3Qt5_glibc2.12-x86_64/squashfs-root/usr/Mod/Arch/ArchMaterial.py", line 333 in onChanged
./AppRun: line 10: 7238 Aborted (core dumped) ${HERE}/usr/bin/FreeCAD "$@"
