What causes "Document::recompute(): Wall007 still touched after recompute"
paullee
Re: What causes "Document::recompute(): Wall007 still touched after recompute"
Post by paullee »
Can you single out the objects and upload the model file - e.g. make a copy, delete those not relevant to keep file size low.
Make some screencaptures.
Thanks.
deffo
Post by deffo »
paullee wrote: Fri Jan 21, 2022 7:08 pm Can you single out the objects and upload the model file - e.g. make a copy, delete those not relevant to keep file size low.
Thanks.
Now everything is ok, I deleted arc door object and that seemed to fix it. I kept door sketch and made new door with arc window tool. The problem occured when door somehow jumped out of the original placement in the wall. Still learning everything and all kinds of wierd stuff happens that I cant explain :D
