Lofting Sketches that contain hole.
I have two sketches that have different shaped holes in the middle of them. They do not show up in the lofting tool with the hole in them. Is there a way to do this?
- sample.png (28.28 KiB) Viewed 1343 times
Re: Lofting Sketches that contain hole.
What shapes, which workbench, which FreeCAD version? Any Model to look at? Please follow the IMPORTANT link above.
Part_Loft Limitations and Complications:
PartDesign Sketches
The profile may be created with a sketch. However only a valid sketch will be shown in the list to be available for selection.
The sketch must contain only one open or closed wire or line (can be multiple lines, if those lines are all connected as they are then a single wire)
That's not quite correct, and that's why I asked for the workbench used:kisolre wrote: ↑Tue Apr 23, 2019 7:34 am Part_Loft Limitations and Complications:PartDesign Sketches
- You must not use PartDesign sketches in Lofts created in Part workbench;
- in Part workbench you can use sketches made directly in Sketcher workbench;
- in PartDesign workbench you can use sketches containing inner closed shapes, e.g. in order to create a tube.
- in PartDesign workbench you have to use sketches from inside if a body, i.e. made in PartDesign workbench.
(If you want to dig deeper, you may learn how to move sketches correctly from outside of a body to the inside).
I was citing the wiki... which was not entirely correct... probably more indepht explanation is needed there. Any way it looks like it works so more info is needed to answer.
Could you provide an example file, your freecad version info,... as Chrisb mentioned above?
Here is an example of working PartDesign Loft:
- PD_Loft.JPG (82.65 KiB) Viewed 1373 times
kisolre wrote: ↑Tue Apr 23, 2019 11:36 am That's not quite correct, and that's why I asked for the workbench used:
I just have to add that the wiki is perfectly correct, detailed and that page was written by a very informed intelligent Australian!
The problem is that I wrote it over 6 years ago, and my last update correcting it to perfection for its time was still 5 years ago. Back then my description was perfect...but time and FreeCAD development move on!
Jim
See my original post. I have added a screenshot of the two sketches. I am using the "Parts" workbench.
So then it's kisolre's guess: In a Part loft inner holes are not allowed and sketches containing such holes don't show up in the list. You have to create an outer and an inner loft and subtract them.
The outer form and the loft central hole provided not to exaggerate with the Bspline.
It's worth remembering that you need as many segments up and down
If we add the two lateral holes, they cross at the center
The solution is to make 1 subtractiv loft and a miror
- bouchon à 3trous.PNG (43.51 KiB) Viewed 1319 times
- bouchon à 3trous.FCStd
- (91.92 KiB) Downloaded 23 times
