The created drawing is not visible
pnagy
Postby pnagy » Tue Apr 23, 2019 10:25 am
I created a part with part design and a drawing with TechDraw. I saved the file but when I open them I see only the 3D geometry. In other cases, both the Page and 3D geometry open in two separate windows. If I create another new drawing, a new window will open. If I click the original Page (this contains the created draw) the program shows the 3D geometry. How can I reach or modify my old drawing on "Page"?
I used Freeecad 0.17 on Windows 7.
Any idea? I attached the part.
camera_tarto.FCStd
(58.02 KiB) Downloaded 27 times
jmaustpc
Re: The created drawing is not visible
Postby jmaustpc » Tue Apr 23, 2019 10:43 am
that is how it is supposed to work.
taht is also what is supposed to happen.
[/quote
Please post your version data in the manner explained in the Forum Rules link above this forum. It provides us much more information.
By the way both your FreeCAD and your O/S are obsolete or are about to be. install FreeCAD 0.18.1 and see if you problems go away. There are something like 3000 feature updates and bug fixes.
I'll look at your file and come back.
jmaustpc
Postby jmaustpc » Tue Apr 23, 2019 11:02 am
I get the following error messages on opening your file.
If you go to FreeCAD preferences and select send error messages to report view and turn on Report view, then you will see the following
Rebuilding Views for: Page/Page
Lines are parallel
Lines are parallel
Lines are parallel
Lines are parallel
Lines are parallel
Lines are parallel
Dimension Dimension004 missing Reference to 3D model. Must be Projected.
Exception (Tue Apr 23 20:53:56 2019): getIndexFromName - empty geometry name
<class 'OSError'>: getIndexFromName - empty geometry name
If I right click on "Page" and select "Show Drawing" I get the following error message
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: getIndexFromName - empty geometry name
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
jmaustpc
Postby jmaustpc » Tue Apr 23, 2019 11:34 am
If I try to delete the drawing it crashes FreeCAD.
Any crash bug is a bug, so....if its not a quick fix, I'll create a bug tracker ticket. Thank you for reporting this.
wandererfan wrote:ping
do you want a ticket?
Jim
jmaustpc
Postby jmaustpc » Tue Apr 23, 2019 11:39 am
here is your file, partially recovered, it has no techdraw drawing, you have to do that again, but I extracted you solid, so at least you won't have to start all over again. Finish the solid first then create the drawing, I have read that the "topological naming" limitation can corrupt a techdraw drawing.
camera_tarto_recovered.FCStd
(51.77 KiB) Downloaded 17 times
kisolre
Postby kisolre » Tue Apr 23, 2019 12:05 pm
On another note you should avoid mapping sketches to faces because of that "topological naming" issues. It already broke here:
See how Face17 changed to the cylindrical side of the hole and the mapping of the next sketch failed.
pnagy
Postby pnagy » Tue Apr 23, 2019 2:57 pm
Thank both of you for the help and quick answers!
wandererfan
Postby wandererfan » Wed Apr 24, 2019 1:18 pm
Yes please. Dimension003 has no references to the drawing geometry. This causes all sorts of trouble since recomputing Dimension003 fails.
I would have thought it was impossible to create such a dimension without using Python (badly).
So there are really 2 problems to solve here:
- prevent a crash when there is garbage in the model
- prevent garbage from being created.
jmaustpc
Postby jmaustpc » Wed Apr 24, 2019 5:31 pm
Bug tracker ticket created.
issue #3944
wandererfan
Postby wandererfan » Thu Apr 25, 2019 12:30 am
issue #3944
git commit ede3bd2210 should fix the crash.
pnagy wrote:
Was there anything unusual about Dimension003? Was the underlying geometry changed after Dimension003 was created? Dimensions without references aren't supposed to happen.
I made up references for Dimension003 to repair the file. You'll want to delete and re-add it with the right end points.
camera_tarto_repaired.FCStd
(58.61 KiB) Downloaded 13 times
