I got message on console on trying:
$ freecad
<quote>
Unknown command 'Draft_Arc_3Points'
</quote>
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
Unknown command 'Draft_Arc_3Points' FC .18
- hardeeprai
H.S.Rai
H.S.Rai
Re: Unknown command 'Draft_Arc_3Points' FC .18
Isn't this a new Draft tool that was only merged in master after 0.18 was released? (Edit: yep, it's only in current 0.19)
How did you install FreeCAD?
I get no such message with the package from the freecad-stable PPA when running it from the terminal.
Version: 0.18.1.
Qt version: 5.9.5
Locale: French/Canada (fr_CA)
Version: 0.18.1.
Qt version: 5.9.5
- hardeeprai
After a lot of struggle and with a lot of help from community.
My reported issue:
https://forum.freecadweb.org/viewtopic. ... 43#p301260
and solution was:
https://forum.freecadweb.org/viewtopic. ... 10#p303216
The difference in your and mine is ONLY of Locale, which should not be the reason for any such message.NormandC wrote: ↑Fri Apr 26, 2019 3:26 amI get no such message with the package from the freecad-stable PPA when running it from the terminal.
Version: 0.18.1.
Qt version: 5.9.5
10c10
< Locale: English/UnitedStates (en_US)
H.S.Rai
H.S.Rai
Ah, my mistake.. went too fast in transferring this command from BIM to Arch and forgot to still properly support older versions. This should be fixed now.
- hardeeprai
Yes. Fixed.
I did:
sudo apt-get update
sudo apt-get install freecad
It updated freecad. On
$ freecad
no such message (of unknown command) got.
Now installed version is 2:0.18.1+dfsg1~201904282142~ubuntu18.04.1
However, Help -> About does not show any difference (from the previous installation):
Version: 0.18.1.
Qt version: 5.9.5
H.S.Rai
H.S.Rai
Often, debian packages propose updates that do not differ from source but fix issues specific to packaging. But in this specific case, the latest update also provides patches from upstream freecad.hardeeprai wrote: ↑Mon Apr 29, 2019 5:13 pm However, Help -> About does not show any difference (from the previous installation):
https://git.launchpad.net/freecad/commi ... 3eb749398d
