Python error, cannot load Addon Manager
Will2
Postby Will2 » Sat Apr 27, 2019 4:22 pm
I found a solution from someone who is having the same problem and I am but I'm not sure how to implement the solution and really don't want to break things. The thread was found here: https://forum.freecadweb.org/viewtopic.php?t=33429
The solution involves deleting some local python packages but I'm not sure which ones and how I should go about it (apt remove?)
This is what I get when I start FreeCAD:
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/will/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/share/freecad/Mod/Ship/InitGui.py
Please look into the log file for further information
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/will/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/share/freecad/Mod/Plot/InitGui.py
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/will/.local/lib/python2.7/site-packages/PySide2/QtGui.so) occurred in /home/will/.FreeCAD/Mod/Manipulator/InitGui.py
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/will/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/share/freecad/Mod/Draft/InitGui.py
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/will/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/share/freecad/Mod/Tux/InitGui.py
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/will/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/share/freecad/Mod/Arch/InitGui.py
And this is what I get when I try and run the addon manager:
Running the Python command 'Std_AddonMgr' failed:
  File "/usr/share/freecad/Mod/AddonManager/AddonManagerGui.py", line 10, in Activated
    import AddonManager
  File "/usr/share/freecad/Mod/AddonManager/AddonManager.py", line 46, in <module>
  File "/usr/share/freecad/Ext/PySide/QtCore.py", line 1, in <module>
    from PySide2.QtCore import *
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 2.7.15rc1
Qt version: 5.9.5
