Fillet on edge between touching/intersecting features
openBrain
Re: Fillet on edge between touching/intersecting features
Postby openBrain » Wed May 15, 2019 9:33 pm
Sullyvan
Postby Sullyvan » Thu May 16, 2019 3:04 pm
I opened the file "bug_fillet_revolution.FCStd" in Freecad. The problem seems to be the seam on the ring. If the cam starts or ends exactly at the seam on the ring, the fillet does not work.
To come back to the example.
If the option "symetric to plane" in Revolution2 is selected for the part "Fillet failed" in Revolution, the fillet works as expected.
In the "Fillet succeed" example, if the cam is turned so that one end of the cam lies directly on the seam on the ring, filleting no longer works.
So the problem seems to be caused by the seam on the ring, and it doesn't matter if the cam is created by Revolution or Pad.
I used the following FreeCad Version:
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Switzerland (de_CH)
openBrain
Postby openBrain » Thu May 16, 2019 4:42 pm
Hi Sullyvan, welcome here,
Could you please provide your complete FC info & a demonstrating file as asked in the IMPORTANT link on top of each forum page ?
EDIT : I actually can't reproduce what you state. ;)
Postby chrisb » Thu May 16, 2019 5:46 pm
It seems indeed to be fixed, left the pad, right the revolution:
Bildschirmfoto 2019-05-16 um 19.45.09.png (27.26 KiB) Viewed 104 times
openBrain
Postby openBrain » Thu May 16, 2019 5:59 pm
Is that the latest daily ? I didn't update mine for a few days now.
Postby chrisb » Thu May 16, 2019 6:20 pm
iuliuv wrote:
Sun Apr 28, 2019 5:33 pm
I retried int_fillet2 from above and it still doesn't work, makes my FreeCAD loop forever, even if I turn the seam out of the conflict area.
Postby chrisb » Thu May 16, 2019 6:24 pm
sorry for ignoring the IMPORTANT link on a red background. It's not the very latest, but quite. Cannot test on Ubuntu, because 16.04 is not packaged yet.
OS: macOS 10.13
Version: 0.19.16694 (Git)
Hash: cd74f2e92908e94f9f7bc718e1be52939647b844
Python version: 3.7.3
Qt version: 5.6.2
openBrain
Postby openBrain » Thu May 16, 2019 10:44 pm
Weird as the file attached to the ticket is actually int_fillet2 where I just copy-paste my example with a pad... :?
Postby chrisb » Thu May 16, 2019 10:54 pm
Iuliuv, did you create that model with 0.18.16110?
Sullyvan
Postby Sullyvan » Fri May 17, 2019 9:27 am
Hello, here is some additional information, as well as a Freecad file to follow the fillets.
I created two components.
One only with the PAD function, the other only with the REVOLVE function.
The fact is, that the cam, which is congruent with the seam of the ring, cannot be rounded, or only partially. The other cam can be rounded at all 4 edges.
Another phenomenon has also occurred. The component created with the PAD function has suddenly become hollow. Also a recalculation of the component only worked once.
Deleting the "Fillet-only-on-two-edges-possible" in the component "1_Body-All-made-from-Pad" solves the problem.
Qt version: 5.6.2
Fillet-Test.FCStd
(93.62 KiB) Downloaded 3 times
Screen Shot 05-17-19 at 11.07 AM.PNG (111.3 KiB) Viewed 57 times
