ODA converter will not install
leong
Postby leong » Sun Apr 28, 2019 4:21 pm
I was trying 0.19_pre and tried to install the ODA File converter as recommended, but it will not install on my system which is an rpm system. Tried the rpm package and got the error message
due to unsatisfied TD_3DSolidHistory.tx()(64bit)
Went to the ODA site and found nothing. Also could not register there to ask a question on their forum. Searched the web and found nothing.
If anyone knows what to do let me know. Thankfully I had previously installed the Teigha converter and that still seems to work in 0.19_pre
Version 0.19
Rev Number: 16502 (Git)
Release date; 2019/04/19 23:15:52
OS: Mageia 6 (KDE//usr/share/xsessions/01plasma)
Version: 0.19.16502 (Git) AppImage
Hash: 06962535fa9ff348acca1b893cc4239908fb8bae
Python version: 3.7.1
Qt version: 5.6.2
Re: ODA converter will not install
Postby Kunda1 » Sat May 04, 2019 1:19 pm
This is concerning. The ODA converter is supposed to replace tiegha. Thanks for posting.
NormandC
Postby NormandC » Sat May 04, 2019 4:23 pm
It's not "supposed to", it already has. But I believe it's actually just a name change along with a newer version.
LibreCAD 2.1.2 can now open DWG files. It opened all the 2D DWG files that I tested (that I had created years ago). Unless LibreCAD can't open some newer DWG files, I don't see the use for the ODA converter - if not considering its batch utility of course.
yorik
Site Admin
Postby yorik » Mon May 06, 2019 2:10 pm
I'm sure at some point we'll be able to get rid of ODA. The libreDWG project has also been worked on, and I saw python bindings in the code too (didn't try yet, though). And librecad people are busy separating their dwg library so it could be used too
the ODA converter is basically one executable and a bunch of libraries (.so files), that all live in the same directory. Maybe you could try to extract the RPM manually (I don't know how to do that, but it's certainly possible) and place all the files in a same directory, that might just work?
john.gibbe
Postby john.gibbe » Mon May 27, 2019 1:36 pm
I've got the same trouble while using FreeCAD_0.19-16540-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage on Mageia 7.
I resolve it by installing ODA Drawings Explorer before ODA File Converter.
Dwg files now open in FreeCAD, except neither texts nor arrows are shown.
ChrisTom
Postby ChrisTom » Sun Sep 15, 2019 12:08 pm
Does not work for Fedora 30:
sudo dnf install ~/P/ODADrawingsExplorer_QT5_lnxX64_4.7dll.rpm ~/P/ODAFileConverter_QT5_lnxX64_4.7dll.rpm
Error:
 Problem 1: conflicting requests
  - nothing provides TrGL2.txr()(64bit) needed by ODADrawingsExplorer-20.8.0.0-1.x86_64
 Problem 2: package ODAFileConverter-20.8.0.0-1.x86_64 requires DbConstraints.tx()(64bit), but none of the providers can be installed
  - package ODAFileConverter-20.8.0.0-1.x86_64 requires TD_3DSolidHistory.tx()(64bit), but none of the providers can be installed
  - conflicting requests
Separate installation of DrawingExplorer at first and ODAFileConverter secondly fails too (in Fedora 30)
Postby Kunda1 » Sun Sep 15, 2019 12:46 pm
Wonder if hobbes1069 can reproduce this as well?
hobbes1069 wrote:
Hey @hobbes1069 care to check this out?
mr-miky
Postby mr-miky » Sat Sep 28, 2019 2:11 pm
I did it this way.
sudo rpm -Uvh --test ODAFileConverter_QT5_lnxX64_4.7dll.rpm
From here we see that only TD_3DSolidHistory.tx () is missing and the other dependencies are already solved
if there were other dependencies you should satisfy them by installing the packages that provide them.
At this point we force the installation using
sudo rpm -ivh ODAFileConverter_QT5_lnxX64_4.7dll.rpm --nodeps
which ODAFileConverter
results : /usr/local/bin/ODAFileConverter
Assuming that TD_3DSolidHistory.tx () is really necessary, I extracted it from ODADrawingsExplorer_QT5_lnxX64_4.7dll.rpm and then copied into:
/usr/local/bin/ODAFileConverter_20.8.0.0/
the permissions on the copied file must be set so that ls -la gives as a result
-rwxrwxrwx 1 root root 696582 28 Sep 15.03 TD_3DSolidHistory.tx
sudo chmod 777 /usr/local/bin/ODAFileConverter_20.8.0.0/TD_3DSolidHistory.tx
sudo chown root:root /usr/local/bin/ODAFileConverter_20.8.0.0/TD_3DSolidHistory.tx
maybe you can even do that, but I haven't tried.
sudo rpm -ivh ODAFileConverter_QT5_lnxX64_4.7dll.rpm ODADrawingsExplorer_QT5_lnxX64_4.7dll.rpm --nodeps
the dependency TrGL2.txr () (64bit) needed by ODADrawingsExplorer-20.8.0.0-1.x86_64 should remain unresolved but we only need ODAFileConverter ;)
ChrisTom
Postby ChrisTom » Tue Oct 01, 2019 3:40 pm
The last mr-milky (from above) solution works very well. Thank You. :)
Montoya88
Postby Montoya88 » Sat Oct 05, 2019 6:24 pm
Curious: Is that because they'll be able to work the .DXF / .Dwg converting ability of ODA into future versions of FreeCAD?
