sketch (non XY) movement problem
bejant
Re: sketch (non XY) movement problem
Postby bejant » Fri Jun 28, 2019 1:41 am
chrisb wrote:
Thu Jun 27, 2019 11:25 pm
Thanks for the clarification. I edited my post to make the references clearer.
Chris, you were sleepy - when you wake up and are well rested, look at your edit again.
You're beating poor Jim up for nothing :lol:
Postby chrisb » Fri Jun 28, 2019 5:34 am
Post is corrected :oops: . For future reference: Please consider that my late night posts may have the opposite meaning of what they say. I opened three quotations of posts from me in separate browser tabs and now I'm afraid of looking at the third quotation of a late night post.
Edit: Phew, at least that one was correct.
Daniel Cocoliso
Postby Daniel Cocoliso » Fri Jun 28, 2019 9:26 pm
Daniel Cocoliso wrote:
Thu Jun 27, 2019 4:59 pm
jmaustpc wrote:
Thu Jun 27, 2019 1:31 am
8) After some more testing, it would seem that the system is remembering the attachment plane of the last few sketches that were in edit mode, and with each recompute it cycles back through them all until you get to the correct one. To see this, enter then exit edit mode for "Sketch", then "Sketch002", and then do the same for "Sketch001" (which is the sketch created by "Duplicate"), then after exiting edit mode for Sketch001 notice its apparent change in attachment plane...click on recompute repeatedly and watch "sketch001" apparently cycle through the attachment planes of the other two in the order in which you had entered/exited edit mode for each.
Right, with your file, every time I recompute the Sketch001, it change form one plane to other, and at the next recompute to the next plane, and so on!
Thanks for all ;-)
Hi all.
This is what I mean, it was marked in blue.
What I mean from the beginning is when you create a copy of a sketch, that is not in the XY plane, if you try to move (I wanted to make a loft, for example), that copy of the sketch automatically rotates to get in the plane XY, and when I leave the move function, the original sketch rotate also to the XY plane.
I hope it is the clear enough. ;-)
bejant
Postby bejant » Sat Jun 29, 2019 2:08 am
I guess you're using FreeCAD 0.18? If so, that's a bug, and it has been fixed in FreeCAD 0.19. You can get FreeCAD 0.19 here:
https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
FreeCAD 0.18 and 0.19 can both coexist on your computer.
The Sketch rotating in the 3D view every time FreeCAD recomputes (the words that you highlighted in blue relate to this) is caused by a problem in the FreeCAD .fcstd file that jmaustpc posted, so it only happens with that file.
jmaustpc
Postby jmaustpc » Sat Jun 29, 2019 4:50 am
After a sleep, I have looked at this again. I missed what was going on earlier and I am now editing the bug ticket. There is a bug in my file, FreeCAD put it in there although admittedly with my help. :)
I found a way to easily create a cyclic dependency because there is a bug in the "Map Sketch" tool in PartDesign. It offers the axis planes of the sketch for selection rather than those of the body etc.. So I had selected "ZX of object" for example, thinking at a glance that the "object" being referred to was the Body, but it was the sketch itself. Obviously this is a bug because why would FreeCAD offer to attach a sketch to an axis plane of itself?
So the bug in my file is easy to reproduce. 1)duplicate or copy paste a sketch, 2) drag it into the active body, then select that sketch and click "Map Sketch" icon, select the same sketch from the drop down list, then select one of the "object's" axis planes.....you then have attached the sketch to itself...a cyclic dependency. :)
another example file
testpartdesignattachment.FCStd
(42.45 KiB) Downloaded 6 times
OS: Ubuntu 18.04.2 LTS (KDE/plasma)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
Postby chrisb » Sat Jun 29, 2019 9:03 am
That's great that you finally found out how these dependencies could have been created!
bejant
Postby bejant » Sat Jun 29, 2019 1:20 pm
Yes, thanks for digging into this, Jim!
Daniel Cocoliso
Postby Daniel Cocoliso » Sat Jun 29, 2019 1:51 pm
Thanks, I'll download it and try it (play with FreeCad :D )
I was checking the FreeCad home page and I could only download 0.18. I didn't fall in search in githug.
jmaustpc
Postby jmaustpc » Sun Jun 30, 2019 5:33 am
look a bit further down on the FreeCAD home page, there is a link that says "development builds" or something like that, which should take you the the downloads on GitHub. If you scroll up and down the github downloads page, you will find the 0.18 release downloads and further down the 0.19 dev snapshots.
Postby chrisb » Sun Jun 30, 2019 6:24 am
It is not easy to see, because you additionally have to click on "Assets" to expand the list of downloads.
