Ticket #3967 - Datum plane yaw setting is ignored
uwestoehr
Postby uwestoehr » Sun May 12, 2019 4:19 pm
Attached is a simple FC file. It contains 2 datum planes.
- I want to make plane 2 make parallel to plane 1 in a defined distance.
- Therefore I edit plane 2 and set its yaw angle to -10°
- In the preview it looks perfect - both planes are parallel
- But when I click OK to finish the editing, the plane yaw angle is reset to 0°, so my change was in fact ignored.
It seems to be a bug.
OS: Windows 7
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Datum-Plane-Bug.FCStd
file to reproduce
(8.3 KiB) Downloaded 13 times
Reason: Added ticket number to thread title
GlouGlou
Re: Datum plane yaw setting is ignored
Postby GlouGlou » Sun May 12, 2019 4:58 pm
Attachment of datum plane 2 should be like this, I think.
uwestoehr
Postby uwestoehr » Sun May 12, 2019 6:48 pm
I purposely did not select plane 1 as reference but the xy-plane. (In the construction where I discovered the problem there is no plane 1 and I try to reference the base planes.) So concerning the xy-plane, I think I did everything correct but the yaw angle setting is simply ignored by FC.
DeepSOIC
Postby DeepSOIC » Sun May 12, 2019 7:23 pm
Seems to be a gimbal lock problem. If I set Pitch to 80, yaw is remembered correctly.
DeepSOIC
Postby DeepSOIC » Sun May 12, 2019 7:29 pm
A simple console snippet to demonstrate that we have a problem:
>>> r1 = App.Rotation(10,90,0)
>>> r1.toEuler()
(0.0, 90.0, 0.0)
>>> r2 = App.Rotation(*r1.toEuler())
>>> r2.isSame(r1)
False
uwestoehr
Postby uwestoehr » Sun May 12, 2019 9:25 pm
Not for me. If I set the pitch to 80° the yaw setting is still ignored while the pitch settings is correctly taken into account.
uwestoehr
Postby uwestoehr » Sun May 12, 2019 9:39 pm
I was not correct. The problem is that the result seems to be dependent on what angle you have set before you made the change.
It gets even more weird if you set e.g. the pitch > 90°. Then the yaw AND the pitch angle turn out wrong.
I opened now issue #3967 as reference.
Re: Ticket #3967 - Datum plane yaw setting is ignored
Postby Kunda1 » Fri Aug 23, 2019 2:59 am
Ticket issue #3967 added to thread title
DeepSOIC
Postby DeepSOIC » Sat Aug 24, 2019 12:38 am
Actually, it should have been fixed. At least, running the console snippet gives True for the isSame test, despite returning different set of angles than one on the input.
OS: Windows 10 (10.0)
Version: 0.19.17803 (Git)
Hash: 89961a33d46063a43e9fb5b0308ca95d559eca94
Python version: 3.6.8
Qt version: 5.12.1
Locale: Russian/Russia (ru_RU)
TheMarkster
Postby TheMarkster » Sat Aug 24, 2019 1:07 am
Werner recently fixed a similar issue with Euler angles in the placement task dialog, which I'm thinking probably fixed this, too. But I don't know if the fix was backported to 0.18.
My FreeCAD video series on youtube: https://www.youtube.com/playlist?list=P ... 48TYSI7GET
