i'm a newbie of freeCAD, and CAD...
i have a STL file, i need to know some normal vector of surfaces,
after lots of Google, here is my answer:
Gui.Selection.getSelectionEx()[0].SubObjects[0].Faces[0].normalAt(0,0).
But when i open my STL file, i cannot choose a surface by mouse?
what should i do?
Thank you very much!
how to get the normal vector of a suface from a STL file
- ufo.zip
- (139.91 KiB) Downloaded 18 times
Re: how to get the normal vector of a suface from a STL file
Try this:
If you are done then run:
def getNormal(cb):
if cb.getEvent().getState() == coin.SoButtonEvent.UP:
pp = cb.getPickedPoint()
if pp:
vec = pp.getNormal().getValue()
index = coin.cast(pp.getDetail(), "SoFaceDetail").getFaceIndex()
print ("Normal: {}, Face index: {}".format(str(vec), index))
from pivy import coin
meth=Gui.ActiveDocument.ActiveView.addEventCallbackPivy(coin.SoMouseButtonEvent.getClassTypeId(), getNormal)
Gui.ActiveDocument.ActiveView.removeEventCallbackPivy(coin.SoMouseButtonEvent.getClassTypeId(), meth)
#documentation
got it, need use part
I'm pretty sure this post will be highly useless if one has the same problem and land here...
