[Solved] Ticket #3979 - pocket "up to face" only one hole
GlouGlou
Postby GlouGlou » Fri May 17, 2019 5:25 pm
Trying to make two holes in this part. Up to face mode make only one. Why this behaviour?
Version: 0.19.16653 (Git)
Hash: aaae82970461c10b76281f4e4454ab086b5f7f21
Python version: 2.7.14
OCC version: 7.2.0
Locale: French/France (fr_FR)
onehole.FCStd
(15.75 KiB) Downloaded 11 times
openBrain
Re: pocket "up to face" only one hole
Postby openBrain » Fri May 17, 2019 6:10 pm
Confirmed here. Guess it's a bug. "Through all" works correctly. ;)
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 2.7.15rc1
Qt version: 5.9.5
quick61
Postby quick61 » Fri May 17, 2019 6:22 pm
Confirmed here as well. Up to face and To first fail, Dimension, (both single and 2 way), and Through all work as expected.
Mark
** Release date 2019/05/15 22:06:43 **
OS: Kubuntu 18.04.2 LTS (KDE/plasma)
Version: 0.19.
Python version: 3.6.7
Qt version: 5.9.5
meme2704
Postby meme2704 » Fri May 17, 2019 7:02 pm
Helas , I confirm too
V.19-pre on windows7
GlouGlou
Postby GlouGlou » Fri May 17, 2019 7:13 pm
bug ticket send. thanks
openBrain
Postby openBrain » Fri May 17, 2019 7:35 pm
issue #3979 ;)
Site Admin
Postby wmayer » Sat Jun 15, 2019 5:46 pm
Some references:
https://www.opencascade.com/doc/occt-7. ... algos.html
It looks like it's either a limitation or a bug in BRepFeat_MakePrism where of the passed profile shape (that's the filled sketch) only one face is used and the second one is ignored.
Btw, the class BRepFeat_MakePrism is also used for the UpToFace option of a pad. So, when you delete the pocket, create a pad, select UpToFace option then it also only creates one cylinder instead of two.
Re: Ticket #3979 - pocket "up to face" only one hole
Postby Kunda1 » Sat Jun 15, 2019 9:45 pm
Updated thread title with relevant ticket #
papyblaise
Postby papyblaise » Sun Jun 16, 2019 4:38 pm
Any problem with V.19_pre
It works well
TheMarkster
Postby TheMarkster » Sun Jun 16, 2019 9:02 pm
I found these comments when browsing through the part design source code:
// A support object is always required and we need to use BRepFeat_MakePrism
// Problem: For Pocket/UpToFirst (or an equivalent Pocket/UpToFace) the resulting shape is invalid
// because the feature does not add any material. This only happens with the "2" option, though
// Note: It might be possible to pass a shell or a compound containing multiple faces
// as the Until parameter of Perform()
// Note: Multiple independent wires are not supported, we should check for that and
// warn the user
// FIXME: If the support shape is not the previous solid in the tree, then there will be unexpected results
// Check supportface for limits, otherwise Perform() throws an exception
Edit: The above was in the FeaturePad.cpp file, so perhaps is not relevant to pocket features?
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
