Adding dimension causes 0.18 to seg fault
ruchg
Postby ruchg » Fri May 17, 2019 8:52 pm
Start FreeCAD by selecting from OS GUI menu
Open drawing of a flat octagon.
File --> Recent --> base.FCStd
Switch to Drawing Dimensioning Workbench
Click on Add Linear Dimension
Pick first point, pick second point, click third point to place dimension, FreeCAD crashes.
Open terminal and type FreeCAD in terminal
Terminal shows:
 <<snip>>
creating dimension dim003
#0  /lib64/libc.so.6(+0x37f40) [0x7f24aeae4f40]
#1  /lib64/libc.so.6(+0x15b9ac) [0x7f24aec089ac]
<<snip>>
Also seen in the terminal window which may or may not be contributing . . .
During initialization the error No module named pivy occurred in /home/ruchg/.FreeCAD/Mod/FreeCAD_assembly2/InitGui.py
which is not surprising since FreeCAD is running Python 2.7:
[ruchg@localhost ~]$ python2
Python 2.7.16 (default, Apr 30 2019, 15:54:43)
[GCC 9.0.1 20190312 (Red Hat 9.0.1-0.10)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import pivy
  File "<stdin>", line 1, in <module>
ImportError: No module named pivy
However Privy is available with Python3
Using:
OS: Linux (Fedora 30)
Version: 0.18.Unknown
Build type: Unknown
Python version: 2.7.15
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
Re: Adding dimension causes 0.18 to seg fault
Postby chrisb » Fri May 17, 2019 10:22 pm
Please note that the Drawing+DrawingDimensioning combo is deprecated in favor of TechDraw.
Although some few things like special symbols are much more difficult to obtain in TechDraw, it is much more advanced in many aspects. You should give it a try.
openBrain
Postby openBrain » Fri May 17, 2019 10:29 pm
Sorry about this question, but why not use TechDraw workbench ?
Drawing Dimensioning is more or less obsolete. ;)
