Some Spherical Boolean Cuts Failing on Cylinder
akehir
Postby akehir » Sun May 19, 2019 12:41 pm
I'm having some issues making spherical boolean cuts on a cylinder. The problem is, that some cuts seem to be inverted, ie. a wall is being created where it should in fact just make a normal cut.
I found a similar bug / issue here:
https://forum.freecadweb.org/viewtopic.php?t=36090
And one potential workaround, which I will try out next:
https://forum.freecadweb.org/viewtopic.php?t=6814
However, I wanted to ask, what exactly the problem might be, and why some of the boolean cuts work, and others don't (for instance, just re-positioning the sphere seems to sometimes fix the problem).
If I'd understand the root cause, I'd probably be able to avoid the problem. Furthermore, it seems to me that making spherical cuts seems to cause bugs under some conditions?
Freecad Version
OS: macOS 10.14
Version: 0.18.16110 (Git)
Branch: (HEAD detached at 0.18.1)
Python version: 3.6.7
Qt version: 5.6.2
(also tried in Windows)
The example files can be found here:
https://akehir.com/cut-operation-1.FCStd
https://akehir.com/cut-operation-2.FCStd
These are how the cuts look for me:
Re: Some Spherical Boolean Cuts Failing on Cylinder
Postby chrisb » Sun May 19, 2019 5:44 pm
I looked at the first file, turning of bottom-ball-hole-003 around the Z-axis solves the problem.
If you face one of these errors, often occurring with coplanar faces, where a tiny move or a rotation fixes a boolean operation there is not much you can do. These are most probably OCC errors. To omit them I only know of the advice to omit coplanar faces.
I would like to add that I hate posts with multiple files attached where I don't know at which file I should look, and which file shows the described behaviour. Less is more.
cut-operation-1_cb.FCStd
(74.46 KiB) Downloaded 1 time
Bildschirmfoto 2019-05-19 um 19.43.12.png (27.8 KiB) Viewed 60 times
cron
