Boolean errors in part workbench
jgamble
Postby jgamble » Thu May 30, 2019 4:46 am
Hi All,
I'm having a strange problem with Boolean operations in the part workbench since updating FreeCAD versions.
Details of current version:
OS: macOS 10.14
Version: 0.18.16117 (Git)
Branch: (HEAD detached at 0.18.2)
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.7
Qt version: 5.6.2
When I attempt to intersect the following parts:
Starting geometry
Screen Shot 2019-05-29 at 9.30.09 PM.png (40.53 KiB) Viewed 145 times
I get the following result:
Result of buggy intersection
Screen Shot 2019-05-29 at 9.30.53 PM.png (27.66 KiB) Viewed 145 times
In the following older version of FreeCAD (details below), this works fine:
OS: Mac OS X
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
The resulting (correct) intersection is:
Correct intersection
Screen Shot 2019-05-29 at 9.38.43 PM.png (10.7 KiB) Viewed 145 times
Geometry file is attached - thanks in advance for any help, and sorry if I missed this issue being reported already!
Cheers,
John
built_simplified.FCStd
Geometry file
(14.35 KiB) Downloaded 11 times
Re: Boolean errors in part workbench
Postby chrisb » Thu May 30, 2019 11:43 am
This is coming from the OCC kernel. Different versions seem to handle the so called coplanar issue differently. The should be avoided anyway whenever possible. If you move shape_2 by e.g. -10nm it succeds.
likewei92
Postby likewei92 » Thu May 30, 2019 3:52 pm
What is the coplanar issue and why should this be avoided? Why is this not just a bug? If it's not a bug, the recommendation is to slightly move one of the shapes?
jgamble
Postby jgamble » Thu May 30, 2019 4:46 pm
Thanks for the response and advice!
Can you please elaborate on the precise move (direction, too) you're using that makes it work? I've tried a variety of moves and it doesn't seem to fix it for me, and I'd love to have this workaround.
Also, is there a bug report in OCC that you know about? It seems like something that should be easy to catch with a test, and I'd be happy to follow up on that in the right venue.
Cheers,
John
Postby chrisb » Thu May 30, 2019 5:25 pm
The coplanar issue is the situation where faces are coplanar, i.e. the faces occupy so to say "the same space". Boolean operations tend to fail for such situations.
This is indeed a bug, which is well known, but there is no possibility for fixing this, as it comes from the OCC geometric kernel.
I attach the file modified according to the explanation above.
OS: macOS 10.13
Version: 0.19.16822 (Git)
Hash: 243aebf2dfbfe192b5bbd067020a5318a0fa8d0d
Python version: 3.7.3
Qt version: 5.6.2
built_simplified_cb.FCStd
(19.04 KiB) Downloaded 3 times
jgamble
Postby jgamble » Thu May 30, 2019 5:35 pm
Thanks! Unfortunately, when I look at the attached FreeCAD file, things still appear to be weird with the intersection (just in a different way). The left side of the resulting arch doesn't appear to be solid (it's missing an interior face). For me it looks like this:
missing face
Screen Shot 2019-05-30 at 10.33.24 AM.png (28.34 KiB) Viewed 95 times
Does it look like that to you, too?
Cheers,
John
Postby chrisb » Thu May 30, 2019 6:12 pm
Yes, it is here the same. If you perform in Part workbench CheckGeometry with BOP Check enabled the result shows lots of self intersections. This is perhaps due to the vertically only slightly inclined faces not being separated enough.
kisolre
Postby kisolre » Thu May 30, 2019 6:44 pm
In your file shape_2 has errors. With the file from the original post and shape_2 at z=-100nm it works ok
OS: Windows 8.1
Version: 0.19.16687 (Git)
Hash: ff1fb11af15a7c5f7f0ba3ef79588e128f397c2c
Python version: 3.6.6
Qt version: 5.6.2
built_simplified_kiss.FCStd
(23.86 KiB) Downloaded 2 times
