[Solved] Fillet geometry error
berka
Postby berka » Tue Jun 04, 2019 11:48 am
I think I'm seeing some geometry "improvisation' by the PartDesign fillet tool. I was able to replicate it in a simple model. (Attached.)
Has anyone else noticed this? Is this a bug to report or is there another explanation?
(All pictures are orthographic).
Overview:
Object Overview.png (51.1 KiB) Viewed 318 times
Right View Before Fillet:
Before Fillet Right.png (8.1 KiB) Viewed 318 times
Right View After Fillet:
After Fillet Right.png (9.48 KiB) Viewed 318 times
OS: macOS 10.14
Version: 0.18.16117 (Git)
Branch: (HEAD detached at 0.18.2)
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.7
Qt version: 5.6.2
After Fillet Top.png (33.33 KiB) Viewed 318 times
filletbug.FCStd
Model replicating issue.
(76.88 KiB) Downloaded 13 times
openBrain
Re: Fillet geometry error
Postby openBrain » Tue Jun 04, 2019 12:02 pm
This is a display artefact, mainly due to deflection setting.
You can change it at body level (view tab of the property editor) - set it to eg. 1° - then force the whole document to recompute by right-clicking on "filletbug" -> "Mark to recompute" -> F5 key. ;)
berka
Postby berka » Tue Jun 04, 2019 3:30 pm
Thank you for that explanation. I suspected display-only artifact, but I was thrown off that it looked the same every way I looked.
GlouGlou
Postby GlouGlou » Tue Jun 04, 2019 9:13 pm
In your file datumplane is not attached, it's not tangent. That gives an error.
aa.FCStd
(68.78 KiB) Downloaded 11 times
berka
Postby berka » Wed Jun 05, 2019 9:50 am
Thanks for taking a look. I intentionally put the datum plane to be slightly below the top of the object. (Z=14.9mm; object has 15mm radius.) That allowed me to show the portion sticking above the plane easily in pictures.
berka
Postby berka » Wed Jun 05, 2019 10:11 am
Tried this morning. This is definitely it. Both Angular deflection and deflection improve the view. More importantly, knowing it's a view artifactly only, and knowing how to affect it are key. It allows me to ignore it or temporarily change it to keep computation faster.
openBrain
Re: [Solved] Fillet geometry error
Postby openBrain » Wed Jun 05, 2019 4:51 pm
This artifact is highly seeable here also because your model is at a very small size. ;)
Also be aware that this parameters will have direct effect on the result if you export as mesh (typically STL).
