Auto detect un-constrained/dimensioned line feature off behaviour
R-INYURU
Postby R-INYURU » Wed Jun 05, 2019 6:40 pm
I saw that in FreeCAD 0.18 there is a feature to help constraint your sketch by clicking on the number of the degree of freedom, I believe it help everyone.
My issue is when I click on it propose me an opposite of the degree of freedom (instead of proposing vertical line it propose horizontal line and vice versa).
Screenshot from 2019-06-05 20-32-23.png (15.36 KiB) Viewed 187 times
For example on the above image the highlighted (green) line is the proposed line but you can see (I guess) that the vertical line is the on needs to be assigned measurement.
Is this how its suppose to happen or its a bug?
My FreeCAD version:
OS: Debian GNU/Linux 9 (stretch)
Version: 0.18.16110 (Git) AppImage
Branch: (HEAD detached at 0.18.1)
Python version: 3.6.7
Qt version: 5.6.2
Trying to learn more about FreeCAD, any idea I will appreciate.
openBrain
Re: Auto detect un-constrained/dimensioned line feature off behaviour
Postby openBrain » Wed Jun 05, 2019 7:33 pm
I just tested with a simple rectangle and it behaves as you expect (ie. the highlighted line is the one without dimension).
May you provide your FCStd file ?
kisolre
Postby kisolre » Wed Jun 05, 2019 8:21 pm
As I understand it it shows one element that can be moved (the horizontal edge) and one place that if constrained will fix that (the left vertex). Since applying vertical distance to any of the vertical lines will constraint the sketch this is only a suggestion. You try to move that vertex, see what moves and decide how to constraint it.
Postby chrisb » Wed Jun 05, 2019 8:27 pm
The solver prposes just one possibility where you can add a constraint which reduces the degrees of freedom. That might not be intuitive or by other means the best choice. In your case you have to answer the question: "Can I move any part of the highlighted element", and here the answer is yes, you can move the whole element vertically.
R-INYURU
Postby R-INYURU » Thu Jun 06, 2019 5:00 pm
Thank you guys I never thought about that, and I tried it and it helps finding the part needs to be constrained.
