Whenever I try to use wall on this sketch (attached, consisting of a straight line and a few arcs), it only ever forms a wall from the straight line. I have fiddled with it but can't seem to get it to cooperate. Any ideas?
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Arch Wall Not Behaving with This Sketch
- example.FCStd
- (4.19 KiB) Downloaded 35 times
Re: Arch Wall Not Behaving with This Sketch
Hi, there are a few bugs fixed about using arcs in sketch in 0.18.
I haven't had chance to open your file atm.
Try if 0.18 already solve your problem.
Though there is error in your sketch - probably due to over-constratints as Sketcher task panel indicates - FC 0.18 build wall based on your sketch.
The file attached was made with 0.18, so if you do not recompute in 0.17, you should see the Wall Extrusion i think.
- example_ FC 0.18.FCStd
- (10.91 KiB) Downloaded 17 times
At home Arch does not work at all with V.19:
Wall, Structure, Armature etc.
nothing works either from a sketch or from zero
I upgraded to 0.18. I can load that file and it appears correct, but even with 0.18 once I recompute it, it breaks again.paullee wrote: ↑Fri Jun 07, 2019 8:00 am Though there is error in your sketch - probably due to over-constratints as Sketcher task panel indicates - FC 0.18 build wall based on your sketch.
No problem recompute here, I am with FreeCAD_0.18-16110-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage on Fedora 29.
FC 0.18-1
OS: Fedora 29 (Workstation Edition)
Version: 0.18.16110 (Git)
Branch: (HEAD detached at 0.18.1)
Python version: 3.6.7
Qt version: 5.6.2
