No module named DraftLayer
abdullah
Postby abdullah » Fri Jun 07, 2019 3:38 pm
I am having a problem when loading a file in FreeCAD with error (repeated several times):
  File "/usr/share/freecad-daily/Mod/Draft/Draft.py", line 74, in <module>
    import DraftLayer
<class 'ModuleNotFoundError'>: No module named 'DraftLayer'
The FreeCAD version:
OS: Ubuntu 18.04.2 LTS (GNOME-Flashback:GNOME/gnome-flashback-metacity)
Version: 0.19.
Python version: 3.6.7
Qt version: 5.9.5
I see no problem in the file after loading it. It is 12 Mb, so the reasons for not having uploaded it.
The question is: why I see this message?
yorik
Site Admin
Re: No module named DraftLayer
Postby yorik » Fri Jun 07, 2019 3:53 pm
Same problem in https://forum.freecadweb.org/viewtopic.php?f=10&t=36888
The DraftLayer.py file is new, but on the FreeCAD side everything is OK, it's there in cmake... I don't understand why it's not in the PPA, is there a list of files that needs to be updated manually?
abdullah
Postby abdullah » Fri Jun 07, 2019 4:12 pm
Same problem
For some reason, all my Draft Clones have been converted into normal objects. I did not realise of this before. May this be related?
I confirm that I have upgraded the freecad-daily package today. I also confirm that DraftLayer.py does not exist in my freecad-daily directory in /usr/share.
As far as I see the inclusion in CMakeList.txt is ok.
yorik
Site Admin
Postby yorik » Sun Jun 09, 2019 5:59 pm
Probably yes.. If the Draft module failed to import because of the missing dependency, that's also where all the Draft objects are defined...
