exporting parts in step : C++ exception thrown (invalid vector subscript)
mnemocron
Postby mnemocron » Sat Jun 08, 2019 9:21 am
I am trying to export a color STEP file from a complex PCB that I imported with StepUp from Kicad.
The PCB alone works, but as soon as I add the traces I cannot export the file anymore in STEP format.
Exporting to .obj works.
I have browsed the Forums but the only thread I found is a similar exception being thrown:
https://forum.freecadweb.org/viewtopic.php?t=28411
I am new to FreeCad. So I don't know how to "simplify" or "fix" a model - should that be the source of my error.
Any help on this issue is appreciated.
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
openBrain
Re: exporting parts in step : C++ exception thrown (invalid vector subscript)
Postby openBrain » Sun Jun 09, 2019 9:20 pm
Hi mnemocron, welcome here. Could you please attach your FCStd file ?
Melk
Postby Melk » Fri Dec 06, 2019 8:53 am
I am experiencing the same problem with two files std when trying to export in step.
These two parts have been completely developped over FreeCAD. You can find them attached below.
Thanx
Manchon perce V9.FCStd
(302.05 KiB) Downloaded 6 times
Adaptateur Manchon V1.FCStd
(201.53 KiB) Downloaded 3 times
openBrain
Postby openBrain » Fri Dec 06, 2019 10:40 am
Hi Melk. Could you add your full FC info ?
I experience no problem here using latest 0.19 to export.
What steps are you doing to export ?
Anyway, you should not use non-ASCII characters in your object names, such as 'ç', 'é', ... ;)
easyw-fc
Postby easyw-fc » Fri Dec 06, 2019 10:44 am
@openBrain, could you please post your STEP export preferences?
I'm having this issue also on latest FC 0.19 (but I'm using legacy exporter)
OS: Windows 10 (10.0)
Version: 0.19.18811 (Git)
Hash: b809867021deb37be1039dab37b9fe1cafab254e
Python version: 3.6.7
Qt version: 5.12.1
and my FC exporting preferences:
openBrain
Postby openBrain » Fri Dec 06, 2019 11:05 am
Here it is :
Melk
Postby Melk » Fri Dec 06, 2019 11:14 am
Hi and thank you for your response.
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Locale: French/France (fr_FR)
The same issue happens with 0.18 version
Melk
Postby Melk » Fri Dec 06, 2019 11:28 am
Export_pref.pngHere it is :
Hi again,
Non-ASCII characters are not well transcripted but this is not the reason of the failure since others non-ASCII characters named files are well exported.
Parameters of export configuration are the same as yours. Do you really think this issue is related to the FreeCAD version ? I think this may be related to the kind of object.
I'm going on to try to solve it
easyw-fc
Postby easyw-fc » Fri Dec 06, 2019 12:21 pm
The issue is on legacy exporter, with your kind of object.
FC0.19 has improved the exporter, but you need to remove the checkbox on legacy exporter.
Anyway this should be reported as an issue on STEP exporter (legacy) present also on FC0.19
openBrain
Postby openBrain » Fri Dec 06, 2019 12:29 pm
I don't know exactly what is messing up the export. What I know is that it already has been solved as latest 0.19 version works well. ;)
Why not trying it ?
