[Solved] Ticket #4015 - Deleting an Object Breaks Expressions
davidhuwmorgan
Postby davidhuwmorgan » Mon Jun 10, 2019 1:35 am
Hello all,
I believe this is a bug.
When deleting an unused object of the same type a reference to a similar object is replace by the object which has been deleted.
Procedure:
1) New Document
2) Go to Part Workbench
3) Create a Cube (name = Cube)
4) Create another cube (name = Cube001)
5) Make Cube001's Z equal to Cube's height using formula editor in the properties dialog.
6) Look in isometric view the boxes are stacked above each other.
7) Create another cube (name = Cube002). All looks good.
8) Delete Cube002 using Combo view.
9) Note the error flagged against Cube001.
10) Cube001's Z in the expression now refers to the non-existent Cube002. <--- not good my model is now broken.
If there's anything else needed to help here, just let me know.
FreeCAD Version:
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
OS:
Windows 10 Pro Version 1803
OS Build 17134.765
FreeCAD log extract:
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: 3Dconnexion device not attached.
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Module: Part
Log: Loading Part module... done
Log: Loading Sketcher module... done
Log: Loading PartDesign module... done
Log: Loading GUI of Part module... done
Log: Loading GUI of Sketcher module... done
Log: Loading GUI of PartDesign module... done
Err: App::Document::recompute(): cyclic dependency detectedErr:
Err: Exception (Sun Jun 9 20:25:50 2019): Property not found: Cube002
Log: Hide main window
Reason: Added [Solved] to thread title
davidhuwmorgan
Re: Deleting an Object Breaks Expressions
Postby davidhuwmorgan » Mon Jun 10, 2019 4:25 am
And just as a follow up,
it doesn't appear to be the delete that breaks the reference to "Cube" but the more like the creation of "Cube002". If after Step 7, I click on "Cube002" cube in the Combo view, then click back on the "Cube001", it can be seen that the Expression for the Z value already references "Cube002". So it seems that the delete merely exposes the change in "Cube001"'s Z value, which can only have been changed during the creation of "Cube002".
OK, hope that helps shed some light,
DHM
openBrain
Postby openBrain » Mon Jun 10, 2019 8:05 am
Confirmed with :
OS: Ubuntu 18.04.2 LTS (KDE/plasma)
Version: 0.19. (2019/06/09)
Python version: 3.6.7
Qt version: 5.9.5
Locale: French/France (fr_FR)
Moreover, when Cube002 is added, FC complains about a "cyclic dependency". ;)
This is a serious weird bug. :) Deserve a ticket.
TheMarkster
Postby TheMarkster » Mon Jun 10, 2019 5:18 pm
Workaround: instead of using Unnamed#Cube.Height use Unnamed#Box.Height in your formula.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
openBrain
Postby openBrain » Mon Jun 10, 2019 5:50 pm
I.e. use the internal name instead of the label. ;)
openBrain
Postby openBrain » Mon Jun 10, 2019 6:16 pm
Oups, was blind it was your first posts here => Welcome to the forum ! :lol:
I created issue #4015
davidhuwmorgan
Postby davidhuwmorgan » Tue Jun 11, 2019 3:21 am
Thanks for opening up the issue report.
I think my workaround is just to always rename an object as soon as its created. Now I know to do that things should be a little easier.
Once again, thanks for the help all.
DHM
jmaustpc
Postby jmaustpc » Tue Jun 11, 2019 6:01 am
DHM
A tip, you may not know, all objects in FreeCAD have both a name which is created by FreeCAD on creation of the object which can not be edited as well as a label which can be edited by a user at any time. It is the label that you see, and can edited, in the GUI. When you use expressions or macros/Python, the difference matters and can be useful. The others are referring to this.
openBrain
Postby openBrain » Tue Jun 11, 2019 7:29 am
Very nice addition, as the obvious may indeed not be for everyone. ;)
@DHM : following jmaustpc, there is an easy way to get the internal name in the GUI. When you hover an object in the tree view with your mouse, the Internal Name is displayed in the status bar (ensure status bar is enabled in View -> Status bar). ;)
Re: Ticket #4015 - Deleting an Object Breaks Expressions
Postby Kunda1 » Mon Jan 06, 2020 3:49 pm
Should we close issue #4015 then ?
