[Solved] Arbitrary cone
Good morning.
Suppose we have the face F of an arbitrary form belonging to some arbitrary object and a point P in space.
Is there any way of building a "cone" whose base being F and its vertex at P?
Regards
Regards
I have uploaded many FreeCAD video tutorials to my YouTube channel
Re: Arbitrary cone
Create the Point in Draft workbench and use Part->Loft. In PartDesign I recommend to create instead of the point an ever so tiny copy of the base sketch for lofting.
Re: Arbitrary cone
Hi
The answer is yes, except that a point is not recognized, it is necessary to create a mini circle (r = 0.01mm)
- cone quelconque.FCStd
- (25.63 KiB) Downloaded 39 times
- cone quelconque.PNG (9.62 KiB) Viewed 1746 times
Re: Arbitrary cone
Excelent!
Using that "non dimensionless point" of Draft Workbech did the job i was looking for.
Thanks a lot.
Re: Arbitrary cone
Thanks a lot for your answer. These two ways of "cheating" loft tool (yours and that of chrisb ) work fine. The users have choices...
Re: Arbitrary cone
Both Part Loft and Part Sweep, can use a vertex/point as a profile, but there are limitations/complications. See the wiki for a detailed explanation.
The point/vertex can be a Draft WB point but there is also a point in Part WB.
Part_Loft particularly under the subtitle "Limitations and complications"
and
Part_Sweep
and
Part_Sweep
Re: Arbitrary cone
Re: Arbitrary cone
When the "vertex" is zoomed in, the (draft) point continues being a point but this is not the case for the small circle.jmaustpc wrote: ↑Tue Jun 11, 2019 11:33 ammeme2704 is wrong, you can use a point. the wiki explains all the complications etc.
Re: Arbitrary cone
Yes, they are different geometry. However in the real world you would not have a genuine point in most cases, since that would mean that the tip is infinitely small, at a practical scale that might seem like it is true but if you looked under a micro scope it would likely be flat or rounded. FreeCAD's standard default precision for Shapes is extremely small, so depending on what you are making the model for, it is possible that you may be better to actually define the point as some other geometry or it may not matter.
Re: Arbitrary cone
Perhaps meme2704 was thinking about the Sketcher point, which indeed cannot be used for such a loft, as it is only construction geometry.
