Radius do not match
Radius do not match
hello, I am use additive wedge and want to add a item to the bottom. But radius does not match up. When i select the radius to measure radius it tell me to select and arc or curve, it is one. How to do this please?
OS: Linux Mint 19.1
Version: 0.18.14555 (Git shallow) AppImage
Branch: (HEAD detached at 2ea4c6a)
Hash: 2ea4c6a81a6449b6880f8a757d0298dd889e0630
Python version: 3.7.1
Qt version: 5.6.2
OS: Linux Mint 19.1
Qt version: 5.6.2
I am taking EASL at night to make my English better. I use VPN for USA better searching
Re: Radius do not match
This is normal as your fillet is on a beveled edge, its cross-section on the XY plane is not an arc but a spline (a quarter of an ellipse in this case).
Fillet being very sensitive to topological naming issue, it is advised to apply it last. Could you model your part with square corners then fillet the whole at the end ?
The external edge carries out an arc of an ellipse. it's a little bit odd. So, to match it, let's make a new arc of ellipse!
- ellipse.FCStd
- (17.51 KiB) Downloaded 7 times
I try thank you. Printing test part with fault radius to see how it look.
Thank you, will try this to.
I try making square corners then round, but worse.
OS: Linux Mint 19.1 (X-Cinnamon/cinnamon)
Version: 0.19.16936 (Git) AppImage
Hash: 6bb8f19b2c8f855880d853c18dab34d576a0843a
Qt version: 5.6.2
Qt version: 5.6.2
Yep. Some FC (or precisely OCCT I guess) limitations.
In the attached file you can find 2 proposals, hope one can match your needs.
The first (left on the picture) uses Draft tool. Thus it only need one sketch, but is sensitive to topological naming issue and fillets radius isn't really mastered.
The second (right on the picture) uses a Loft between the primary sketch and a CarbonCopy of it where I changed the overall dimensions. It's a bit more complex, but immune to toponame changes, and fillets radius can be finely tuned.
Feel free to require more details if needed.
- wedgeOB.FCStd
- (45.72 KiB) Downloaded 7 times
Thank you, but I get corner overlap in first post.
Thank you, I will study methods.
