Creating a hole from a "Bolts" created SHS
Laurie Hartley
Postby Laurie Hartley » Sat Jun 15, 2019 5:59 am
I am having great difficulty in creating a hole on two opposite sides and ends of an SHS that I created using the "BOLTS" Macro. I am still a novice using FreeCad but have had some success creating holes, pockets and pads with other parts but this one has got me stumped.
I have attached the file. I am trying to cut a circular profile starting 32.5mm from each end and on two opposite sides SHS.
I have been trying using the Part Design workbench.
Help with were I am going wrong and the workflow would be greatly appreciated.
OS: Windows 8.1
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Chord 65mm.FCStd
(12.7 KiB) Downloaded 10 times
Bance
Re: Creating a hole from a "Bolts" created SHS
Postby Bance » Sat Jun 15, 2019 7:38 am
You need to drag and drop the extruded section into the body, this will create a base feature that can be pocketed.
You will also need to modify your sketch since it has open vertices....
See included file.
HTH Steve
Chord 65mmbance.FCStd
(36.87 KiB) Downloaded 12 times
Laurie Hartley
Postby Laurie Hartley » Sat Jun 15, 2019 10:10 am
Thanks Steve - I will follow your instructions and post the outcome
Laurie Hartley
Postby Laurie Hartley » Sat Jun 15, 2019 10:54 am
So far so good - progress - see attached file. Just got to do the same on the other end now!
Chord 65mm Updated.FCStd
(69.78 KiB) Downloaded 11 times
Postby chrisb » Sat Jun 15, 2019 10:08 pm
What is SHS?
Laurie Hartley
Postby Laurie Hartley » Sun Jun 16, 2019 1:16 am
Chris - SHS is an abbreviation for Square Hollow Section - a steel product that comes in many cross section sizes, wall thicknesses, and lengths. Here is a link to a product information brochure.
http://www.austubemills.com.au/uploads/ ... _Apr18.pdf
Postby chrisb » Sun Jun 16, 2019 5:17 am
Thanks, I had googled it, but doing so in germany I got plenty of explanations of which none made any sense.
Laurie Hartley
Postby Laurie Hartley » Thu Jun 20, 2019 1:42 am
As promised here is my completed part. I really appreciate your advice Steve (Bance). It saved me hours of going round in circles.
Chord 65mm Final.FCStd
(142.13 KiB) Downloaded 10 times
Postby chrisb » Thu Jun 20, 2019 6:50 am
This has nothing to do with the topic, but allow me some comments on your sketching. I had a look at "end profile":
- You almost never need dimensions of 0. Use constraints such as vertical or horizontal or point-on-object or tangency instead
- You should prefer geometric constraints in favor of dimensions
- Have a second look at your sketch if equal dimensions occur, also exact halves of dimensions are suspect
Furthermore there is a bug in the solver which makes it assume that your sketch is fully constrained, which in fact it isn't. The leftmost vertical line can be moved freeely in horizontal direction. (I should add that I don't have a2plus installed.)
Abdullah wrote:ping
I could change your old version containing 7 dimensions (where one more was missing) and 15 constraints ...
Bildschirmfoto 2019-06-20 um 08.42.51.png (20.16 KiB) Viewed 238 times
... to a sketch using only 3 dimensions and 12 constraints:
Bildschirmfoto 2019-06-20 um 08.47.03.png (15.08 KiB) Viewed 238 times
Postby chrisb » Thu Jun 20, 2019 6:54 am
And here is one more: Instead of repeating the sketch construction you could have used a Mirror pattern. That would have been even easier, if you had positioned your object symmetric to the origin.
